different tires and 4wd
Old Jan 29, 2004 | 07:11 PM
fordeverpower's Avatar
fordeverpower
Question different tires and 4wd
Can you run different size tires on the front then the back or does this mess up stuff with 4wd?
Old Jan 30, 2004 | 03:11 PM
teds74ford's Avatar
teds74ford
NO! He he! Seriously, You can run different widths, but diameters will creat a few problems. They could break something, but if it is slippery enough, you should have no problems. My family has a habit of running whatever on their farm trucks, but what it does is make it hard to get out of 4wd because of driveline bind. Then you have to back up while pushing on the lever, and it will pop out. Still, the best is to use the same size tire.
Old Jan 30, 2004 | 10:23 PM
fordeverpower
thanks for the reply!
