Pullriight ISR 5th wheel installed
Old Jan 15, 2017 | 09:24 AM
porthole's Avatar
porthole
Originally Posted by johndeerefarmer
Is that red carabiner for your brake cable? If so you need to connect your brake cable to the rails not the hitch. If the hitch happens to break and come loose then your brakes won't engage.
RE trsailersaver ts3:
You could probably leave the pins that hold the hitch to the adapter plate out and the hitch still wouldn't come out.
The concern for that hitch would be the head assembly or the head mount failing.
On edit - forget this, missed that you were referring to the PullRite hitch and not the ts3 in the next post
Old Jan 15, 2017 | 09:31 AM
17 Oaks's Avatar
17 Oaks
Had a couple of those in the bed of the truck along with some hitch pins and hung them on there to get them off the floor when working in the bed. I attach my brake wire to a tie down next to my electrical connection.
Old Jan 15, 2017 | 09:42 AM
johndeerefarmer's Avatar
johndeerefarmer
Very good.
I attached mine to the tiedown in the corner of the bed with a carabiner
Old Jan 15, 2017 | 09:45 AM
17 Oaks's Avatar
17 Oaks
Originally Posted by cyncwby
Here's my TS3 Trailer Saver and adapter and as said, yea they are heavy, combined right at 400 lbs. My engine hoist makes it easy though, yea they are expensive.....if you buy them new. After a LOT of looking I bought this barely used 4 yr. old hitch for $1300 shipped to the house. The adapter plate I found on Ebay ...... $55 !! the shipping cost more than the plate. I would NEVER go back to a non- air bag hitch.
WOW!!
You got a deal, it sells for $2795 + cost of the air compressor.
RA101725
Apr 26, 2019 10:53 PM
uscgmkcret03
6.7L Power Stroke Diesel
Aug 15, 2013 09:21 PM
George D.
Mar 5, 2008 09:24 PM
MMarty
All Things Towing
Mar 6, 2007 04:52 PM
chopperdude
Feb 17, 2002 11:50 AM
