Thermostat Bad?
Old Jan 11, 2017 | 04:57 PM
WolfCreek540's Avatar
WolfCreek540
Thermostat Bad?
I have 2006 F350 and it suddenly has no heat. Temps are EOT 165ish and ECT 160ish according to DashBoss fully warmed up. I have the King Ranch heat controls which continue to mystify me sometimes. I set it for 65 degrees and cold air blows. No difference between ambient temps of 35 vs. -30. No heat.
Radiator and coolant drained/replaced 6 months ago. Wouldn't mind replacing the Tstat myself as long as I get a day above freezing to do it. Does this sound like the reason I have no heat or is there a vacuum line or heater core problem? Troubleshooting tips?
Old Jan 11, 2017 | 05:04 PM
WatsonR's Avatar
WatsonR
Replace the t-Stat and verify the vacuum line is connected to the he heater bypass valve.... right next to the oil fill tube on the heater hose. It's a grey plug, vacuum hose.
diesel_dan's Avatar
diesel_dan
Yes your thermostat is bad -- it is low by 25-30 degrees. Don't know if that will affect cab heat but your mileage will go up...
Old Jan 11, 2017 | 05:08 PM
69cj's Avatar
69cj
T-Stat is where I'd start. Make sure it's an OEM.
Old Jan 11, 2017 | 08:41 PM
Per4mance's Avatar
Per4mance
I like the Mishimoto t stat. Heat is killer and fuel economy went up. They are just a little pricey. Lifetime warranty thou.
Old Jan 12, 2017 | 08:28 AM
WolfCreek540
Thanks guys. I will check the vacuum hose and wait for a warmer day to switch the stat. Might have to wait until April at this rate. I am beginning to intensely dislike winter.
Old Jan 12, 2017 | 10:11 AM
WatsonR's Avatar
WatsonR
That low temperature is costing you fuel mileage as well. Less than 185°, it's dumping fuel to it trying to warm it above 185°, probably a couple miles per gallon.
Old Apr 30, 2017 | 11:01 PM
WolfCreek540
An update: It's finally warm enough to do the thermostat switch, so I tackled the stat this afternoon. Love the fact that it has an O-ring instead of using gasket sealant. It would be a breeze to change if you didn't have to remove the air filter for easier access. I hate everything about that air filter set-up! Next time I will do it without removing anything except the top radiator hose.
Temps on the test drive warmed up quickly to 190-195 degrees and then stabilized there. My deltas were within 5 degrees at 65 mph and 60 degrees air temp, whereas before it wouldn't get above 170, no matter what. Most of the time coolant and oil temps were within 2 degrees of each other. Can't ask for better than that.
Never would have known there was a problem if I didn't have DashBoss. That and the truck wouldn't make heat driving in -20 degree F weather. Idaho is the land of extremes sometimes. On Friday I mowed grass while it snowed like crazy on me!
Old May 1, 2017 | 03:16 AM
WatsonR's Avatar
WatsonR
Where at in Idaho?
Old May 1, 2017 | 09:29 AM
Rod Jr.'s Avatar
Rod Jr.
What brand thermostat did you go with?
Old May 1, 2017 | 10:39 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
If it takes more than about a minute you're doing it wrong. It comes out in one piece.
No idea why this guy removes the flexible bypass hose, that last step is unnecessary:
Jon Barnes
Dec 17, 2014 11:05 AM
jayc3169
Sep 16, 2011 09:56 PM
Lariatblues
Apr 3, 2009 11:07 AM
sctrailrider
Aerostar
Nov 14, 2007 10:45 PM
hu5ker555
Jan 22, 2005 07:34 PM
