Aerostar Ford Aerostar
Lost heat...
Old Nov 13, 2007 | 12:14 PM
sctrailrider's Avatar
sctrailrider
Lost heat...
Once again I am calling on the Aerostar Brain Trust...
Replaced the heater core January 2006. Solved the leak problem but the heat output never got back up to the level I had prior to the repair. Last spring we repalced the water pump. Now there is not even a hint of heat coming out. Neither heater hose gets warm. Thermostat opens OK, based on the heat coming from the top radiator hose. I pulled the heater hose at the thermostat housing and seem to be getting flow out of the housing. Is it possible the heater hoses/core have become airlocked and no coolant is getting the core?
Old Nov 13, 2007 | 01:45 PM
bertha66's Avatar
bertha66
Is the temp gage coming up to normal? I'm thinking the thermostat is no closing good and not litting the water heat up.
Old Nov 13, 2007 | 02:43 PM
VanGo's Avatar
VanGo
Both hoses will be hot if the t-stat is opening.
With your engine cold, take off your rad cap. The coolant will be relatively still until the t-stat opens. You'll know when/if it does open. You'll see some flow thru the rad.
Old Nov 13, 2007 | 06:09 PM
96_4wdr's Avatar
96_4wdr
1 plugged or collapsed heater hose, they break down from the inside and look perfect on the outside
2. 96 and later have vacuum controlled heater line valve that stops coolant flow when heater is turned off or AC is on, yours failed closed?
some shops install these or electrical ones in hot climates S. USA
3. heater damper door not opening, damaged vacuum line
4. mice have been known to get into heater box and plug it up with their nest building, usually stinks which is the tip off.
5. heater lines were installed in reverse onto the core. affects air purging and air blockage
Old Nov 14, 2007 | 11:54 AM
sctrailrider
Heater hoses are installed like this...
Water Pump outlet to top of heater core.
Thermostat outlet to bottom of heater core.
Old Nov 14, 2007 | 10:45 PM
96_4wdr's Avatar
96_4wdr
hose connection flow correct for 4L
Stang_Shane
Jan 9, 2017 06:15 AM
Kenneth J Kirkland
Dec 23, 2016 02:47 PM
Buckland14
Modular V8 (4.6L, 5.4L)
Nov 10, 2016 06:28 PM
Ford Breakdown
1983 - 2012 Ranger & B-Series
Nov 5, 2016 06:53 AM
NTENSE
Oct 26, 2016 02:18 AM
