Finally
Old Jan 29, 2017 | 05:29 PM
  #31
Rollingscrapmetal's Avatar
Rollingscrapmetal
Problem solved
Old Feb 6, 2017 | 09:34 AM
  #32
Rollingscrapmetal
So 460 time what's it gonna take
I have a bell housing 79 351m I'm guessing I need a new flywheel 351m probably and as far as motor mounts I would prefer new perches but is it possible to use my current ones
​​​​​​​Is there a specific year 460 I need can I make an efi one carb
Old Feb 7, 2017 | 08:45 PM
  #33
bigdan1979f-250's Avatar
bigdan1979f-250
Slow it down a notch. You just asked for like 50 pages worth of info in one paragraph. The 460 route is a good one, many different people have done it several different ways. If you are going to use the 351/400 bellhousing you are either going to have to use the expensive L and L flywheel and clutch or get a 390 flywheel and have it modified if need be. I did the L and L route, much simpler. 351/400 flywheel will NOT work. You could try and find a mid 80s donor and use the motor and tranny. They used a hydraulic clutch setup. Do a search on here for info, there's plenty of it.
Old Feb 10, 2017 | 04:22 PM
  #34
Rollingscrapmetal
OK so here's a thought I take a 460 with a 460 flywheel I take the ring gear off (176?) And cut it to accept the smaller 180 tooth ring gear assuming it uses a smaller minor diameter if it's the same yay
OK so my next issue obviously becomes the gear depth assuming it is different I would set the depth so I don't need some wierd starter
Old Feb 11, 2017 | 11:45 AM
  #35
Rollingscrapmetal
Can I get some pictures of starters specifically 460 and 351 starters
Old Feb 11, 2017 | 02:12 PM
  #36
fordguy2100's Avatar
fordguy2100
http://lmgtfy.com/?t=i&q=351+starter
http://lmgtfy.com/?t=i&q=460+starter
Old Feb 18, 2017 | 01:18 PM
  #37
Rollingscrapmetal
Does anyone know the imbalance on a 460 flywheel
Old Mar 9, 2017 | 07:39 PM
  #38
Rollingscrapmetal
I finally pulled the motor apart it threw a rod which broke the camshaft plus both head gaskets were blown the drivers side had burn marks on the gasket and 6-7 were filled with coolant
But I was right the ticking at least partially was valves hitting the piston no. 2 broke and it had obvious damage to the piston and a few metal shavings in the head
Old Mar 9, 2017 | 07:54 PM
  #39
PapaBearYuma's Avatar
PapaBearYuma
guess that explains why it finally quit running. You going with the aforementioned 460 or doing something else?
Old Mar 9, 2017 | 10:48 PM
  #40
Rollingscrapmetal
After all the changed plans and the miscarriage that was my deployment all the parts for the 460 got split up into other vehicles so long story short a rebuilt 390 is the new plan
Old Mar 9, 2017 | 10:59 PM
  #41
PapaBearYuma
Sounds like a good plan! Good luck and keep us informed!
Old Mar 10, 2017 | 12:17 PM
  #42
Rollingscrapmetal
Anybody got any opinions on the heads being any good other than the bits of piston nothing seems wrong
Also any ideas on what could cause 2 blown head gaskets and if they're related to the other damage
Old Mar 21, 2017 | 09:10 PM
  #43
Rollingscrapmetal
Well it happened again they're threatening to impound it for being "abandoned" and despite the fact that I was there this time to tell them it wasn't abandoned I still got a warning
So now we're going to play games and hide a monster truck until the new motor gets here
So I'm going to take a 7'7" truck and hide it in the 7'6" parking garage it should be fun
Old Mar 21, 2017 | 09:28 PM
  #44
Tedster9's Avatar
Tedster9
Who is "they"?
Old Mar 21, 2017 | 09:32 PM
  #45
fordguy2100
Air down the tires as much as safely possible, may let you just squeak by.
