Another Glow Plug Relay question
Old Jan 19, 2017 | 05:10 PM
Walleye Hunter's Avatar
Walleye Hunter
Originally Posted by coax9952
That's not a large Voltage drop....1.1 Volt? Load drop.....
This is what I'm thinking too. I have cig lighter volt meter and it drops into the 10's with initial key on and increases to 11's after what I think is the glow plugs warmed up. Then up to 12 when they shut off altogether.
Old Jan 19, 2017 | 10:18 PM
snakedoc's Avatar
snakedoc
Sounds like more then I get on the big relay
And please never use ether just jump the relay with a screw driver.
Old Jan 19, 2017 | 11:50 PM
aaron8669's Avatar
aaron8669
Also, you should prob touch your two fingers together for 30 sec and see what the resistance of your cables of your ohms meter is. That should always be subtracted from the resistance you are seeing total. It's not uncommon to see a .2-.5 ohms of resistance just through your tester. So with that being said, it may not be that big of a drop. However, if it is 1 ohm, I do think that is a little high for a new relay.
Oldschoolfordlover86
Jun 29, 2014 03:40 PM
Eallend7
30
Jan 24, 2013 06:13 AM
powerstroker100
May 28, 2010 12:37 PM
jjav8tor
Oct 24, 2004 06:52 PM
mpbpulaski
Oct 17, 2004 10:28 AM
