Glow plug relay test
Old Oct 24, 2004 | 05:18 PM
jjav8tor's Avatar
jjav8tor
I tested the voltage across my glow plug relay on my 97 350 7.3 with the key on. It is getting hard to start. There is about a two volt drop across the relay. Should the voltage be exactly the same as the battery voltage? all of the glow plugs check out fine.
Old Oct 24, 2004 | 05:35 PM
Quadzilla's Avatar
Quadzilla
There should be about 0.5V drop across the relay if it's a NAPA or Autozone relay, less if it's a Stancor. At 2.0V, I'd be thinking you should invest in a new relay. They're available through NAPA for about $23, and the part number is GPR-109.
Old Oct 24, 2004 | 06:52 PM
jjav8tor's Avatar
jjav8tor
Thanks. That's what I thought.
1'stonraceday
Mar 28, 2014 07:07 AM
kweiss
Dec 19, 2012 07:12 AM
Rus01
Mar 26, 2011 02:23 PM
fast freddie
Nov 9, 2004 07:38 PM
edstoner
Dec 10, 2002 06:13 AM
