glow plugs
Old Jun 28, 2014 | 07:48 PM
Oldschoolfordlover86's Avatar
glow plugs
Hey guys I have a glow plug problem i am in the process of by passing the glow plug controler when I pulled the purple wire off the relay and tried to test it from the relay to the battery when I did this nothing happened so I thought maybe the relay was bad so I changed it and that still didn't fix it so I thought maybe i got a bad relay so I bought another one and when I tried testing it again with a wire straight from the relay to the battery still nothing happened how ever when i by pass the relay all together the system works so I have no idea what's going on. Please help
Old Jun 29, 2014 | 01:33 AM
Macrobb's Avatar
Macrobb
The relay needs both power and ground - one small terminal to 12V, one to ground.
The way the system works is that one terminal goes to key switched B+, and the other goes through the controller to ground.
Old Jun 29, 2014 | 03:40 PM
Got it thank you for the help
jtak101
17
Jan 19, 2017 11:50 PM
Ravenous Weasel
Jan 17, 2012 08:30 AM
powerstroker100
May 28, 2010 12:37 PM
dbrugger
Jan 6, 2009 07:32 PM
mpbpulaski
Oct 17, 2004 10:28 AM
