Rear cab mounts
Old Jan 10, 2017 | 03:41 PM
Classicdriver's Avatar
Classicdriver
Rear cab mounts
hi, I noticed this the other day. Rear cab mounts on '70 f100. Shouldn't there be nuts and washers on there?? .
Thanks
Dan
Old Jan 10, 2017 | 04:28 PM
351Cleveland C4's Avatar
351Cleveland C4
Yes.......
Old Jan 10, 2017 | 04:30 PM
kenny nunez's Avatar
kenny nunez
Body mount
The lower washer is threaded and fits inside the rubber. It can be a real problem if the threads are rusted together. If so you will need to fold the washer down on 2 sides to get a grip on it.
Old Jan 10, 2017 | 04:52 PM
351Cleveland C4
Hmmm. I'm pretty sure mine have nuts. But then again I've never really paid attention.
Old Jan 10, 2017 | 05:06 PM
Brian1971f100's Avatar
Brian1971f100
No nuts. x2 on the body mount being threaded.
Old Jan 10, 2017 | 07:53 PM
Ford_Six's Avatar
Ford_Six
Yup, that lower washer is the nut. Really sucks when they get rusty and the washer spins, I had to cut the ones on my old truck.
Old Jan 10, 2017 | 09:10 PM
GaryKip's Avatar
GaryKip
Good to know, thanks!
Old Jan 11, 2017 | 07:53 AM
Classicdriver
Ok great, thanks for all the input. I wondered if it was something funky like that. Next question would be, then do they look tight enough? I'm thinking they do not, and wonder if I can hear them shift when going around the corners. I don't hear it everytime, but this truck is solid and when I do hear something I want to find it and fix it. Thanks
Dan
Old Jan 11, 2017 | 08:07 AM
Brian1971f100
Look under your seat. The bolts are accessible. Make sure the holes in the body are not enlarged and check that the body around the mount is in good shape. When I was taking mine apart I found the floor cracked around one of the mounts. Nothing a welder wouldn't cure.
Old Jan 11, 2017 | 12:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Jan 11, 2017 | 09:58 PM
Ford_Six's Avatar
Ford_Six
Interesting considering I have never found nuts on those on the four trucks I have pulled the cab off of. The front cab mounts yes, but not the rears.
Also, the bolts are under the tank. It'll have to come out before the bolts can be removed.
Old Jan 12, 2017 | 08:09 AM
Classicdriver
Thanks Bill, guess that answers it.
Old Jan 12, 2017 | 08:51 AM
Brian1971f100
I have never found read cab mount nuts ether. No need for it as the bottom washer is an insert into the top washer and is threaded. Adding a second nut will only cause aggravation trying to remove it.
Old Jan 13, 2017 | 08:13 AM
f100today's Avatar
f100today
Every factory rear cab mount I have taken off did not have a nut. The washer insert thingy was threaded.
Old Jan 14, 2017 | 04:35 AM
GaryKip's Avatar
GaryKip
I've got to drop the Aux tank for basically the same reason. The front, drivers side bed bolt ripped a hole into the bed. I guess when the PO backed into something with the tailgate down, it strained it a little.-LOL
