Always stuck. Only 1 tire spins
Got a 1990 f250 7.5 2wd
When I got the truck the back tires didnt have much life left so I decided to dick around and burnout to use up the last of the tread. I noticed I was only leaving one burnout mark.
So now out of the 2 rear tires, one is completely bald and the only has a little tread.
Went to pull out of my driveway this morning and after some rain it was muddy. I have a flat driveway and I couldnt even get out of the drive! My bald tire was in the mud and my good tire on the pavement. The bald tire would spin and Id go nowhere. Had to back up and get a running start.
Why didnt the other tire on the pavement engage once the bald tire started to spin? I get that each tire gets its own power but I thought once one started to spin more power would go to the other tire.
Thanks in advance
Thanks in advance
That is an "open" differential. It applies power to basically one tire at a time. Leaving you stuck if one tire is on anything slippery. The one way to get power transferred over is to ride the brake enough to stop the spinning tire and it will then put the power to the other tire. It does work, but only if you have rear brakes that work well(many times they are so far out of adjustment they don't do much).
If you had a "traction lok", it would apply power to both tires simultaneously.
You may have a TL, but if the clutches are worn, it will turn into a "one wheelie peelie".
I get it's an open diff. But I thought if one tire was spinning it would apply power to the non spinning wheel. I just sat there and spun even though the tire that has tread was on pavement. If the pavement tire would have spun I should have had no issues. If I replace the clutches would it solve my problem?
No clutches in an open diff......that's why its called "open"....
And here's a guide to differentials I wrote up that you might find helpful
https://www.ford-trucks.com/forums/1...erentials.html
