IDS Clone
Old Jan 10, 2017 | 01:35 AM
2006F250SuperDuty's Avatar
2006F250SuperDuty
IDS Clone
Yahiko,
Thanks for contacting me. Do you have anything already prepared you can email me? How much, anything I'd need to know. I'm a real noob on this vehicle. 2005 F250 Super Duty with the 6.0. I've had it about 8 months.
I've redone the head gaskets, ARP studs, oil cooler, EGR delete, coolant filter, change to ELC, 6.4 banjo bolts, new stand pipes with the teflon, updated dummy plugs 12 MM.
My wish list is parallel the battery cables with new ground, delete fuel and oil filter assembly on the top of the engine with bigger fuel supply lines routed to the back of the heads with a new regulator, remote air cooled oil filter, bypass oil filter assembly, water pump with steel impellers, bigger alternator, navigation with satilite stereo, 08 transmission filter and pan, 08 side mirrors, 5" turbo back straight exhaust, and doing something with the turbo, bigger??, adding camber bushing assembly as described by powerstrokehelp guy, and learning more about the FICM flash and PCM flash. My understanding so far is there's better available.
So with my wish list I believe I've mostly done what I could do without needing AE or the IDS. I've done all this work myself in my garage with the cab on. It's been fun learning and I want to do my wish list as money allows.
Old Jan 10, 2017 | 11:38 AM
Burgess090906's Avatar
Burgess090906
Don't waste your money on AE.
It's a glorified code reader that can do a buzz test and live read data.
Not good for much else.
Old Jan 10, 2017 | 01:51 PM
seijirou's Avatar
seijirou
by chance can the IDS clone fix the speedometer when changing tire size?
Old Jan 10, 2017 | 03:23 PM
F33lmywrath's Avatar
F33lmywrath
Yes it can. I used my clone to do exactly this.
Old Jan 10, 2017 | 09:06 PM
seijirou's Avatar
seijirou
Good to know, thank you.
Old Jan 11, 2017 | 03:46 AM
Yahiko's Avatar
Yahiko
Originally Posted by 2006F250SuperDuty
Yahiko,
I sent you an email with my address.
Old Jan 11, 2017 | 09:38 AM
Copper.Farm's Avatar
Copper.Farm
Yahiko has this down.
Old Jan 11, 2017 | 03:57 PM
Yahiko's Avatar
Yahiko
Just an FYI :
Chinese New Year on the 15 and the factory shuts down for 3 weeks.
Cookie Monstero
Jun 12, 2012 08:58 PM
Jayybird
Mar 5, 2010 09:47 PM
indyraven
Nov 25, 2007 11:35 PM
enoree
Apr 21, 2006 11:01 PM
RussB
Oct 5, 2004 08:49 AM
