code 44
Old Jan 9, 2017 | 04:11 PM
Fordfan86's Avatar
Fordfan86
code 44
pulled codes on my 1989 ford f250 with a efi 5.0 and am getting number 44 koer.
going to replace vacuum lines and see if that helps, the only symptoms I'm getting is when the truck is in park or neutral and I hold the throttle the motor bogs down every 3 or 4 seconds. it seems to be lacking power as well but I'm not sure if that is related. any suggestions would be appreciated.
I believe the code is Thermactor system fault (right side).
Old Jan 11, 2017 | 04:43 PM
rla2005's Avatar
rla2005
What are the KOEO and stored codes?
Old Jan 12, 2017 | 07:12 PM
Fordfan86's Avatar
Fordfan86
I had codes 67 and 87 with koeo
and koeo it just has 44
update: went through the vacuum lines and the one going down to the check valve next to the air pump was dangling. haven't had the chance to check codes again.
Old Jan 13, 2017 | 07:10 AM
rla2005's Avatar
rla2005
Code 67 (KOEO): Neutral Drive Switch (NDS) circuit open; A/C ON (Manual)
Code 87 (KOEO/CM): Primary fuel pump circuit failure
Neither of those is a show stopper but it's highly suggested to start with the KOEO/CM diagnosis before jumping to KOER codes.
mjricha.isu
Nov 26, 2013 07:24 PM
fordmudrunner2020
Apr 30, 2005 09:37 PM
daf
Jan 19, 2004 02:18 PM
gnfshn1218
Bronco II
Oct 27, 2003 01:42 PM
scott9320
Mar 6, 2002 09:22 AM
