I'm trying to figure how to over-ride the 'one-touch' down option for the driver's side window. Can't remember how it was done in the past, just need it to respond like the others. Thanks in advance. (It's for my '96 Explorer LE).
It doesn't respond to two quick clicks? Normally if you hit it twice it will stop from going all the way down, and then just go as far as you hold the button.
Here's the post for someone installing the second generation Taurus "Express down" module in his Bronco. It's probably the same part in your Explorer. The Taurus module is kept under the armrest inside the door panel. I'd imagine the Explorer location is similar.
