disable power steering
Old Aug 27, 2003 | 04:50 AM
Hammy211's Avatar
Hammy211
Hi. First post. I was wondering it the power steering can be disabled for some performance gains? This would be along the same lines as a disable switch for your alternator. Anyone know if this can be done on a vulcun? I'm not to worried about the steering, it can't be much harder than it was on the Mazda B2200s of the 80's.
Old Aug 27, 2003 | 07:02 AM
PSKSAM2's Avatar
PSKSAM2
Welcome to FTE!
I've had a power steering fluid leak on an '89 Sable 3.0L. It became really tough to turn. Way harder than my buddy's '83 Porsche with non-power steering (which is a real pain at low speed). So first off, I wouldn't suggest it.
As far as being able to do it, I would think that you'd need to put some sort of a clutch in there so that you could stop the pulley from spinning the pump. On the alternator, you can remove the field so that it doesn't charge the battery, and the entire assembly effectively becomes an idler pulley, but still spins. On the PS pump, there is a direct mechanical connection (as far as I know) and you couldn't just clip a wire to stop it from turning.
I wouldn't even switch off the alternator as you'd be running down your battery. I don't know if there is a set of underdrive pulleys for our trucks out there, but that would probably be a safer bet. It's one of the first power mods most Mustang owners make.
-Jim
Old Aug 27, 2003 | 08:23 AM
Rockledge's Avatar
Rockledge
Originally posted by PSKSAM2
Welcome to FTE!....I don't know if there is a set of underdrive pulleys for our trucks out there, but that would probably be a safer bet. It's one of the first power mods most Mustang owners make.
I agree with Jim. I wouldn't play around with the power steering or alternator just to gain (maybe) a few hp. A guy over at The Ranger Station sells underdrive pulleys for the 3.0L vulcan...from all accounts that I have read, they work pretty well (I do not have any personal experience with them, however): Click Here for More Info
P.S. Welcome to Ford Truck Enthusiasts!
Old Aug 27, 2003 | 10:44 AM
Ken00's Avatar
Ken00
The steering would be much harder than a vehicle without power steering because you would have the added resistance of pushing the fluid as well as turning the truck. In a safe place try putting it in neutral and shutting the engine off and see how hard it is to turn.
Old Aug 30, 2003 | 01:50 AM
AlfredB1979's Avatar
AlfredB1979
Also, the gearing in a P/S-equipped truck is waaay different than that of the non-P/S trucks. That matters.
If you don't want P/S, find an XL model and swap gearboxes and yank off the pump.
FWIW, I've had a 69 VW Bug and a 93 Isuzu truck and they weren't bad at all without P/S in them. Even in tight spots. Maybe I can find an XL Ranger and swap those gears in and have P/S as well...
Old Aug 30, 2003 | 02:26 AM
Hammy211's Avatar
Hammy211
I wish I had the ability to do that my self. Somewhere I read said PS sucked signigicant power (10hp) when active. I figured that without it the truck would do a little better coming out of the corners at least. My mom has a 88 B2200. Think I could swap parts with it? It wasn't a problem w/o PS. Do you know if the belt for the power steering is also used for the water pump in the vulcun engine?
Old Aug 30, 2003 | 02:28 PM
mrwizard's Avatar
mrwizard
For those that are contemplating this modification, have you ever driven a vehicle that has power steering without the power steering working? It is NOTHING like driving a vehicle that didn't come with P/S from the factory.
Old Aug 30, 2003 | 02:43 PM
Hammy211's Avatar
Hammy211
Yah, that's what the guy said two posts above. Don't think anyone has disagreed.
Old Aug 31, 2003 | 01:23 AM
dono's Avatar
dono
Gone but not forgotten.
I could be wrong, but I doubt that the power steering pump pulls any where near 10 HP.
Dono
Old Aug 31, 2003 | 02:10 AM
Hammy211's Avatar
Hammy211
Yah, I wish I could remember where I read that at. Some page I found when I searched "free mods"
Old Aug 31, 2003 | 02:13 AM
Hammy211's Avatar
Hammy211
I didn't see underdrive pulleys in for the vulcan in the supplied link. Would they be something he would have if I asked.
Old Aug 31, 2003 | 07:28 AM
Rockledge's Avatar
Rockledge
In the thread that I referenced above, there is a link that you have to click in the first post.
Dono in '04
surreyboy
6.7L Power Stroke Diesel
Nov 2, 2015 12:07 PM
saltbranch
6.2L V8
26
Mar 26, 2014 01:23 AM
2000expedition4x4
24
Aug 13, 2010 06:23 PM
22's
16
Sep 25, 2008 03:58 PM
jeffdoerr
15
Jul 22, 2007 05:19 PM
