All gauge components not working on dashboard (Oil gauge/Heat thermostat gauge..etc.) I thought originally it was the voltage stabilizer and had it replaced, maybe it’s the instrument cluster printed circuit that has gone bad. Any ideas?
The gauge lights work, and the voltage regulator had been replaced although previous regulator did allow some movement of the gauges it did not give an accurate reading on oil or heat, at the moment no movement since VR replacement.
As for the fuel gauge this has not worked since purchase and think it needs a new sending unit which is another story.
I just attached the dashboard assembly for my 1974 F100, is this another word for IP PCB?
