Sweaty cab
Old Jan 5, 2017 | 10:23 AM
Reddman's Avatar
Reddman
Sweaty cab
Hi all,
Has anyone found a good fix for the roofs of our trucks. When it's cold out (15* right now) the roof on my 79 sweats so bad you would swear your in a rain forest, frozen. Will a roll on bed liner work? What have you guy's done?
Thanks for any input.
Reddman
Old Jan 5, 2017 | 12:31 PM
copeina's Avatar
copeina
Crack a window and get the humidity down. Get some good floor mats you can shake the water/ice off of as needed. Kick the snow off your boots before yout get in.
15F is a warm day here and I have no issue. At -30 it gets a little frosty but still nothing like you describe.
Is there a chance your heater core is leaking? That will steam up a cab real quick.
Happy January!
Old Jan 5, 2017 | 12:49 PM
HIO Silver's Avatar
HIO Silver
That's what causes roof rail rot. When enough condensation forms, it'll accumulate and trickle its way to the rail and eventually rot out. The PO of my 70 parked it on a side slope so the passenger side rail is toast whereas the driver side is perfect.
Insulate the roof panel and the issue will go away. Tuck stuff down the side and front rails too... your roof will thank you.
Old Jan 5, 2017 | 12:50 PM
mikeceli's Avatar
mikeceli
I keep a few rolls of this
https://www.lowes.com/pd/Frost-King-...lation/1081449
When I open up a door or roof, I usually add some to quiet and insulate. I used it doubled up, on the generator box of my Toyhauler Trailer. It really quieted it down.
It is much cheaper than the name brand sound deadeners. My only concern, is if it might retain water, on a floor or inner door? It is rubber foam on aluminium foil.
On one of my 2, 1996 Impala SS's, I used a lot of it when I installed new carpet and upholstery. That car is very quiet.
meangreen92's Avatar
meangreen92
Ah yeah, good point. Make sure the cab is sealed up well. Any solid, liquid, or gaseous H2O which gets in there will only contribute to this problem.
Perhaps there is some sort of desiccant pack stout enough to have the desired effect against this moisture. If you can get a dehumidifier in there, that should dry things out. And if you have working AC, then run the compressor with your heat when you drive it.
And are you asking about protecting against this unwanted water cycle with the bed-liner? A bed-liner coating will protect the precious metal, but won't stop water from condensing on itself.
The cold outside air keeps the roof-skin cold, and when the cab is heated from the inside, ambient moisture condenses on the warm side of the roof, just like it does on the outside of your favorite cold canned-beverage, in a room-temperature setting...
Old Jan 5, 2017 | 12:54 PM
mikeceli's Avatar
mikeceli
PS It is dense, closed cell (I believe) foam rubber.
Old Jan 6, 2017 | 08:38 AM
Reddman's Avatar
Reddman
Thanks guy's,
This truck is a F350 Dually, dump bed,460 auto.
I only drive this truck a couple time a month since it is a farm truck. So from the advice I guess the best place to start is patching the hole in the floor boards next to the gas pedal. (it never bothered me since my foot doesn't fall through)Then I will look into some sort vapor barrier/insulation.
Thanks again.
Reddman
bpimm
13
Jan 28, 2018 08:56 AM
Demonhawk
18
Nov 13, 2015 08:58 PM
droldsmorland
Jul 29, 2014 11:41 AM
tpolley
Oct 24, 2008 03:10 PM
fordxxx
13
Jan 28, 2005 05:10 PM
