Need Type 8 Mirrors ?
Old Jul 7, 2016 | 02:05 PM
Leef250's Avatar
Leef250
Hi, so I know that no one makes the Type 8 mirrors anymore but does anyone know where I might be able to get some, or does anyone have a good set for sale ?
Old Jul 7, 2016 | 03:32 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
PM sent.
Old Jul 8, 2016 | 11:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Lower pic: Do you need the entire mirror or just the mirror head?
Old Jul 9, 2016 | 01:03 AM
Leef250's Avatar
Leef250
need the whole mirror, complete set up. times 2. want to swap from my mirrors to type 8 if it's possible to still get them.
Old Jul 9, 2016 | 01:44 PM
77&79F250's Avatar
77&79F250
You mean these? Yes the one set that is "swung in" has a small bend in the R/H mirror lower arm, and BOTH sets are Ford, at least the heads are for sure. Like I said, I think they might be off a newer year rig 80ish? Due to the longer lower arms? Let me know if they will work and we can set up a deal thru PM's.
Can anyone confirm the lower are length for an older set?
Old Jul 10, 2016 | 02:14 AM
Leef250's Avatar
Leef250
I'm not sure about different lengths for different years, hopefully someone else here will know and help out with that. I'm sure both will work. Lets hope someone here can give more info. Thanks.
Old Aug 23, 2016 | 06:26 PM
Leef250's Avatar
Leef250
does anyone have pictures or measurements on where exactly to mount the type 8 mirrors at? any help would be appreciated and also any tips on how to make them be and stay more secure, etc when mounted. any and all tips are greatly appreciated.
Thanks
Old Aug 23, 2016 | 07:19 PM
77&79F250's Avatar
77&79F250
When you get the measurements, measure 10 times and drill once. Unless you can get the OEM style inserts (nutserts?) and the proper tool to install them, go with new stainless hdwr and Nord Lock washers and stainless nuts from the backside.
Carefully remove the door panels and use allen head stainless bolts, Nord Lock washers and stainless nuts. Use longer tan GM push pins to remount the door panels. Also lube the window regulator and the window roller track since you are in there.
https://www.northwestfastener.com/fa...FYGEaQod5DsL2g
Old Aug 23, 2016 | 09:54 PM
Leef250's Avatar
Leef250
I will go get the new hardware, but am still hoping someone here can send a good pic and / or measurements of the proper mounting location. Thanks.
Old Aug 24, 2016 | 01:04 PM
youngblood1989's Avatar
youngblood1989
My 78 F-150 had the type 8 mirrors. They are off the door so I got the measurements. These are off the passenger side:
From the top edge of the door down to center of hole, 7-3/8", 3 holes 3/8" dia. From front edge of door, first hole is 12-3/8", second hole is 16-1/8", and third hole is 19-7/8". The bottom two holes are 15-11/16" from the bottom edge of the door. First hole is 9-7/8" from front of door edge, second hole is 22-1/4"(roughly, as hole is kinda rusty). I also took pics as well, message me if you want them.
Old Aug 29, 2016 | 01:13 AM
Sam's1967's Avatar
Sam's1967
This is why I love this forum!
Old Aug 31, 2016 | 10:08 AM
Leef250's Avatar
Leef250
thank you.
Old Jan 6, 2017 | 09:49 AM
Leef250's Avatar
Leef250
Hey all,
So I have this set here of Type 8 Mirrors to put on my 79 F250 4x4 and am just now getting around to being ready to put them on. Had a few other things that I was doing to the truck first before the mirrors are ready to be installed. So anyways, I'm changing from Type 7 to Type 8 and was wondering if anyone knows where I can get the installation kit for installing the new mirrors at ? The plastic spacer or bushings, whatever they're called that go between the door and the mirror base, the nuts, bolts, and washers.. etc... If anyone knows of a place that still sells them, preferably as a complete kit would be nice but either way, please help me out and let me know where I might be able to find the parts at. Thanks.
Old Jan 6, 2017 | 10:08 AM
NumberDummy
I'm changing from Type 7 to Type 8 and was wondering if anyone knows where I can get the installation kit for installing the new mirrors at ? The plastic spacer or bushings (FoMoCo: fastener), whatever they're called that go between the door and the mirror base, the nuts, bolts, and washers.. etc... If anyone knows of a place that still sells them, preferably as a complete kit would be nice but either way, please help me out and let me know where I might be able to find the parts at. Thanks.
DOAZ-6455180-A .. Fastener (inserts into door for type 8 mirrors) / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 148 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 242 = 800-543-4959.
D5TZ-17724-A .. Upper Gasket - 3 mounting holes / Obsolete
GREEN SALES CO. has 7.
57032-S40 .. Bolt - 1/4" -20 x 1 5/32" / Obsolete ~ No one has any.
Parts shown as 55180 .. 17724 .. 57032-S in lower pic.
Old Jan 6, 2017 | 11:18 AM
Leef250's Avatar
Leef250
thanks, called them and got the parts ordered.
amdriven2liv
Jul 29, 2012 01:57 PM
1964Goat
Feb 8, 2012 12:13 AM
TimTheGuitarMan
Jun 21, 2006 03:44 AM
89CrewCab
Jul 31, 2003 03:39 PM
Hondo
Aug 29, 2001 11:54 AM
