Correct Filter Kit C-6 ?
Old Jan 4, 2017 | 12:12 PM
jakeharp's Avatar
jakeharp
Question Correct Filter Kit C-6 ?
Want to start flushing and sealing my C6, there seem to be a lot of generic filter kits and then I see some that delineate 4wd ? Looks like the 4wd kits have a short spout that comes down off the filter housing for a pickup in a deeper pan Im not home right now and wont have it off until the weekend, thought I would ask before I order a filter kit..... coming off a 76' F250 4wd........ and I have no reason to believe its not the original tranny. Thanks in advance....... Also any recommendations has to a brand or make for the filter kit, or does it really matter for that ?
Old Jan 6, 2017 | 05:55 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
As far as I remember, the pan was it. I think the 4x4 pan was like deeper or higher capacity maybe, not sure why. maybe they figured extra slopes needed more oil. I thought when I did it the kits came with both sumps, and you used the deep or shallow for what you needed.
Old Jan 6, 2017 | 10:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
4WD's use a different C6 pan and filter than 2WD
D3TZ-7A098-B (replaced D3TZ-7A098-A) .. Filter (Motorcraft FT-48) / Obsolete ~ Available NOS & from auto parts stores.
1973/91 F100/250 4WD / 1978/91 Bronco / 1979/91 F350 4WD
Old Jan 6, 2017 | 10:59 AM
Aaron-71's Avatar
Aaron-71
You are correct good sir!
Here's what the 4WD and 2WD filters look like, taken from my own build thread.
Note that you MUST KEEP your pick-up tube for the 4x4 filter! These are not supplied with the filter and cost extra ($$$$).
Thanks to GIGGER, I'm putting in the proper transmission filter (thanks again for noticing this GIGGER!).
4x4 filter out.
2WD (proper) filter in. Lubed up like crazy because I want to keep the interals wet until I actually install this C6 in my truck. Currently it's all lubed and prepped, just needs to be filled.
Old Jan 6, 2017 | 02:04 PM
jakeharp's Avatar
jakeharp
Thumbs up Perfect Thank U
Thanks guys, think I understand now and can order a filter...... I knew there had to be a difference....
jakeharp
Jan 4, 2017 06:01 PM
drfordcal
Aug 1, 2011 11:35 AM
fl1a
Sep 24, 2010 04:45 PM
Farmboypowerstroke
May 10, 2010 09:58 PM
danlee
19
Jan 13, 2009 08:25 PM
