I just bought a 1996 psd xlt 4x4 for 4 k. 156 k miles and in real good shape. The guy I bought it from had 3 psd s alltogether. Was selling oldest one. It runs great but when I get up to speeds over 60 it looses power and dies out. When I check the pressure valve on the bottom of the fuel bowl air comes out and truck starts back up. I have noticed fuel leaking from out the back of the fuel valley but have not been able to pinpoint the exact leak location. Not to much leaking but it only leaks intermittently. Would this be a fuel pump problem?
I'm not OCD in fact under my hood is pretty dirty but it is dry. So that is what I'd do is dry every thing up whatever takes. If I see any wet spot I find it and fix it.
Well I bought the truck Sunday 1-1-17. He said it had a few little issues. I'm working off the list but was curious about if I were correct about fuel pump. I'm a little OCD when it comes to my trucks also. Believe me this psd will be gone over quite well by the time I am thru. It runs wonderfull around town but as soon as I jump up to about 65 to 70 is when the dying begins.it doesn't smoke, its stock and it starts first hit even in 5 below with no heater plugged in.
if you could get it on a scanner that will tell you a lot but it does not give you fuel pressure but you could get TP and IVS and a lot of others.With only 156k I wouldn't think fuel pump and kinda a PITA to change especially if it is not your problem.
Thanks so much for that info! It makes the most sense out of everything I have heard. I do have a fuel leak. I know that for sure. Every little fix I have done to this truck it just keeps getting better and better.
Rather than throwing parts (which may all have been replaced recently anyway) at it, TEST. Shotgunning parts gets expensive, and can be counter-productive when you replace a potentially nearly new part with a bad aftermarket one. Get the valley clean and DRY, and spread baby powder in it (in the absence of baby powder, use baking soda). Start and run the engine, and rev it up to exercise the lift pump and bring up fuel pressure. The powder will help pinpoint the location of the leak. It could be something as simple as the fuel filter sensor, which is a VERY common leak source. The sensor's function has NO impact on engine operation, so if you're willing to be vigilant about changing the filter, you can replace it with an NPT plug. That's just one example of a variety of possible leak sources, all of which could be affecting fuel pressure at high load.
