I smell fuel!
Old Feb 18, 2003 | 10:15 PM
MikeFrank's Avatar
MikeFrank
Unhappy I smell fuel!
I have been smelling fresh fuel after using my 1997 PSD F-250. I found evidence of fuel in the valley pan. My local shop tells me the O-ring on the bottom of the fuel pump has failed. They say this is a common problem and pretty expensive to repair. Comments?
Old Feb 19, 2003 | 05:19 AM
Quadzilla's Avatar
Quadzilla
I smell fuel!
What they're telling you might be true, but before I bought into that, I'd check to see if there's a leak around the fuel filter cap. If the wrong gasket was used, or it wasn't tightened down completely, you can get a leak there.
Old Feb 20, 2003 | 08:01 PM
MikeFrank's Avatar
MikeFrank
I smell fuel!
Thanks Quad....Here is what we found
The o-ring in the fuel pump was leaking. A pressure test revealed that it was low on delivery pressure. It was replaced and now everything is good again.
