How To Install remote start "Advanced"
Old Jan 3, 2017 | 07:16 PM
fastback89's Avatar
fastback89
I finally got around to getting remote start turned on with FORscan, all the tips and video was a big help. Does anyone know how to activate the last part of the install for the instrument cluster to show in the settings menu? I'm not even sure of which module to open.
Old Jan 4, 2017 | 12:59 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
If you have an MS-CAN OBD II adapter you can enable it in ForScan. Let me know if you have one, and I'll find the settings to modify to enable it.
For me, I just went to Ford, told them my remote start was active, but the gauge cluster menu was not there, and if they could reactivate the whole thing. They did, and didn't charge me anything.
Old Jan 4, 2017 | 07:50 AM
paintballdude05's Avatar
paintballdude05
I changed the following and it ended up working for me.
Remote Start: In 726-19-01, change 0047 (disabled) to 0148 (enabled).
Remote Start Menu in Cluster: In 720-01-02, change EC0A (disabled) to EF2A(enabled).
Old Jan 4, 2017 | 08:39 AM
fastback89's Avatar
fastback89
Thanks I will give it a try
Old Jan 4, 2017 | 06:15 PM
fastback89's Avatar
fastback89
My truck may be different.
720-01-02 = 4C0A is what I see in the cluster module, not EC0A.
It is an FX4 so that might be the problem? I tried changing it but wouldn't take those numbers. Thanks for your help I'll keep searching...
Old Jan 4, 2017 | 07:07 PM
paintballdude05
You might have to look up some vins from an FX4 or Lariat that had the RS factory installed. That way you can get the as-built from those trucks and look at what's written on the 720-01-02 line.
Old Jan 4, 2017 | 07:28 PM
Olytlr's Avatar
Olytlr
Try on line 720-01-02 xxxx-EF2A-xxxx
Forscan may show an issue with the hex values but will correct automatically and put in the correct value.
Old Jan 29, 2017 | 03:16 PM
fastback89's Avatar
fastback89
If anyone is interested in getting there remote start to show up in the settings menu, I figured it out with a little help from the FORscan forums. In IPC module 710-01-02 change just the middle 2 from C0 to F2. My dash is FX so it went from 4C0A to 4F2A. I think this works in most of the dash configurations.
Old Oct 6, 2017 | 02:38 PM
hughnormus's Avatar
hughnormus
I just wanted to give a shout out, thank you and confirm that these settings worked on my 2013 F150 XLT.
Remote Start: In 726-19-01, change 0047 (disabled) to 0148 (enabled).Remote Start Menu in Cluster: In 720-01-02, change EC0A (disabled) to EF2A(enabled).Additional Comments to finding these settings:
  • The settings to enable remote start are found in the Body Control Module (AS BUILT format)
  • The Instrument Panel Cluster settings are found in the
    IPC Module Configuration (AS BUILT format)
I used Forscan to write the changes (made backups first in Forscan). I heard in the youtube video I reference below that your ODB II connector needs to have MS-CAN to get into the instrument panel settings. The ODB II > USB cable I purchased was $23 off of Amazon, "bbfly-BF32302 ELM327 USB modified FTDI chip OBD2 ELMconfig Forscan HS-CAN / MS-CAN OBD". This wasn't packaged with the driver I needed for Win 7, but I did find it after some hunting on the site they recommend. See below. Forscan's website has a list of compatible devices. I chose an ELM327 for it's HSCAN/MSCAN capability so I could get into the instrument cluster settings.
Other material I used in my information gathering (bits and pieces of the puzzle I had to put together):
Old Oct 8, 2017 | 12:02 PM
artscott61's Avatar
artscott61
Veteran: Navy
I just purchased a 2014 f-150 so am I to understand that the truck already has most of the remote start installed and all I have to do is follow the video?
Old Oct 8, 2017 | 12:34 PM
jdunk54nl's Avatar
jdunk54nl
yes. that is correct. Every truck has it, it just needs to be turned on either by dealer or using forscan and add the key/antenna.
snotrod
2015 + Expedition & Navigator
Apr 4, 2018 04:00 PM
Steve White
Dec 18, 2017 10:14 AM
A/Ox4
2009 - 2014 F150
26
Mar 8, 2017 12:37 PM
