2.9 no start
Old Feb 6, 2017 | 04:02 PM
  #106
87 XLT's Avatar
87 XLT
I keep thinking about the injectors only firing after releasing the key from the start position.
Try this very simple little test. Turn the key to the run position, remove the R/LB (red light blue stripe) wire from the starter relay take a pair of pliers or screw driver and jump 12 volts to that pin. Be sure it's in park if it's a slugomatic or neutral if it's a stick shift because it should crank and start when you do this
If it fires right up when you do this take a look at your start/ignition diagram. See how R/LB is spliced from the neutral safety switch to the starter relay & to the ignition module. The wire might be broken between the splice and the IM or the IM is bad.
As you can see on your diagram this simple test bypasses the start circuit in the IM.
Old Feb 10, 2017 | 07:38 PM
  #107
John Faccinto Jr.'s Avatar
John Faccinto Jr.
I replaced the IM and still nothing. I tried my best to follow the wire back but I didn't find and breaks in the engine compartment.
Old Feb 10, 2017 | 10:32 PM
  #108
Lead Head's Avatar
Lead Head
Did you try doing like he said, and jumping the starter solenoid while they is in the "On' position?
Old Feb 11, 2017 | 09:49 AM
  #109
John Faccinto Jr.
I did jump the solenoid but I was getting the same results with the injectors not firing
Old Feb 11, 2017 | 09:54 AM
  #110
Lead Head's Avatar
Lead Head
You should get a multimeter and hook it up to the injector +12v line and verify they're getting power while cranking.
Old Feb 11, 2017 | 10:10 AM
  #111
John Faccinto Jr.
I'm getting 12 volts to both positive and negative sides of the injector while key is on.
While cranking both drop to 9 volts.
Old Feb 11, 2017 | 10:40 AM
  #112
Lead Head's Avatar
Lead Head
Okay, your injectors are not losing power then. Next put your meter on the coil positive, and do the same. Then, put it on the "ICM Power Pin" (http://img.photobucket.com/albums/v8...4.gif~original) and do the same there as well.
Old Feb 11, 2017 | 10:53 AM
  #113
John Faccinto Jr.
With key on I'm getting 12 volts from the coil that drops down to 9 volts and the same for the IM
Old Feb 11, 2017 | 11:58 AM
  #114
John Faccinto Jr.
Using a test light I tested the signal from the PiP sensor and found I wasn't getting any pulse
Old Feb 11, 2017 | 01:12 PM
  #115
Lead Head's Avatar
Lead Head
In that case, the PIP sensor inside the distributor is likely weak or failing, since the power going to the TFI, coil and injectors is constant.
Old Feb 11, 2017 | 01:26 PM
  #116
John Faccinto Jr.
Another thing that I'm gonna check first is the pins at the computer. Pin 58-59 ground out the injectors while pin 37 is the supply power
I want to test these and also recheck the pip
I believe it runs 12 volts but I want to make sure
Old Feb 11, 2017 | 02:35 PM
  #117
Lead Head's Avatar
Lead Head
Keep us updated
Old Feb 11, 2017 | 03:34 PM
  #118
John Faccinto Jr.
Using a test light, I tested to see if there was constant power at the injector connector. I got constant power while cranking.
Next I tried the ground on the injector connector and got nothing while cranking.
I moved to the pins that connect to the computer. I used pin 37 as my power source and probed to pin 58 and 59 with the test light. If the bulb began to flash, then I would be pulsing to ground and I would have bad wires going to the injectors. Once again I didn't get any pulse.
I looked into the PIP again and didn't get anything from it either. I believe that my wires are good going to and from the injectors and that the pip is at fault.
Old Feb 11, 2017 | 08:17 PM
  #119
pawpaw's Avatar
pawpaw
Is your test lamp a high impedance/low electrical load LED type?
Old Feb 15, 2017 | 05:53 PM
  #120
John Faccinto Jr.
I got the old sears-bulb test lamp.
This is really off topic but why did some trucks have MAF and others didn't?
