Transit Connect 2010+ Ford Transit Connect
Front End Vibration
Old Jan 2, 2017 | 09:33 PM
adamkat22's Avatar
adamkat22
Front End Vibration
Sorry...I feel like I'm blowing up this forum with questions recently, but I appreciate everyones advice/feedback as I enter the TC world.
I test drove two 2010 TC's today. One had 90k miles and the other had 60k miles.Both of them had noticeable vibrations in the front end (the 90k one was worse than the other), and a considerable amount of road noise (but it only seemed prevalent during acceleration).
The guy with the 90K TC said that this is normal for these cars. The guy with the 60k TC said it will be fixed before I bought it (although he said it pretty unconvincgly).
Is this indeed normal? If not...what is it an indication of?
Old Jan 3, 2017 | 07:18 AM
Frantz's Avatar
Frantz
The old ones are very noisy, especially after driving a '14+. Vibrations are not "characteristic" though, meaning, something's not quite right. I don't know of any know go to issues, but I'd check the obvious, tires, alignment, worn joints. Worn out suspension components on any cargo van is pretty common.
Old Aug 1, 2017 | 07:07 AM
b1corr's Avatar
b1corr
I have a 2010 TC and the vibration noise is awful. It is noticeable when I crank it up and also upon acceleration. I thought it was for sure the axles. I purchased new ones and when I installed them, I knew I was on the wrong track when I noticed that the ones that I removed were also almost new. I am wondering if maybe the engine mounts may be the problem as the vibrations are present when the van isn’t moving and just idling. Has anyone found the source of the vibrations?
Old Sep 28, 2017 | 07:21 AM
winginit's Avatar
winginit
I had a 13 tc and now a 16 the 13 vibrated during braking dealer said it was warped rotors. i dont know if thats the fix because i traded for a 16. now this one virbrates slighty during braking. both low miles under 20k
Nick 99 E350 v10
Oct 30, 2015 08:13 AM
Camp250
Feb 7, 2012 09:03 AM
2011 SUPER DUTY6.7 L
Oct 1, 2011 03:34 PM
Seven4t8
2004 - 2008 F150
Mar 27, 2005 10:48 PM
clubwagoneer
Sep 17, 2000 07:46 PM
