6.0, 2004 neutral switch
Old Jan 2, 2017 | 08:52 PM
Ibwheels25's Avatar
Ibwheels25
Is the neutral switch on a 2004, 6.0 inside the tranny pan? It's not on the outside of the trans. And not under the dash as far as I can see. Any help would be appreciated.
Old Jan 2, 2017 | 09:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, it's inside the trans pan.
Old Jan 2, 2017 | 10:06 PM
Ibwheels25's Avatar
Ibwheels25
Thank you for the info, now I will try to adjust the shifting cable first to hopefully fix the no crank issue. By moving shifter back and forth a lot It started in neutral twice then was able to start it in park once. Seams like an adjustment is needed. I hope it is not the switch. Any thoughts?
squinne
Jan 16, 2016 07:36 AM
danlee
Electrical Systems/Wiring
Sep 18, 2013 01:42 PM
eddie50
2004 - 2008 F150
Oct 15, 2012 04:55 PM
deyomatic
Aug 6, 2009 02:05 AM
tsheriff
Dec 21, 2004 09:39 AM
