Brake Line for Hutch Mod??(Drawing!)
Hi Guys While gathering parts to do the Hutch mod on my truck, I found this brake line made by AGS Company of Muskegon, Michigan. Of course I will call them & see what they say about using the coating in diesel fuel but I wanted to ask what I consider a 'more informed' group. What do ya think??
Here is what they say about their 'Poly Armor' coated brake line on their website: Poly-Armour® is different from anything else on the market due to its PVF or Poly-Vinyl Fluorine coat. This coating is actually a highly durable 'plastic' coating that is 'baked and cured' to the line. This provides extra protection from corrosion, debris, and road surfacing solutions. It also offers superior bend-ability without kinking that makes Poly-Armour® the most easy to work with line - period! Underneath the PVF-coating is a double-wall, low carbon steel, copper brazed tubing which meets all international and U.S. requirements for brake tubing. The difference being that Poly-Armour® offers 30 times the corrosion resistance of galvanized steel alone. PVF-coated lines are now the standard in many vehicles on the road today, including: Volkswagen/Audi, Honda, Toyota, and Mercedes. Considered a premium line Poly-Armour® should be used on any vehicle that will see any type of harsh environment, including snow, road treatments, salt air, dirt/gravel, etc...Poly-Armour® should also be used when extending the life of the lines is important, such as on commercial vehicles or when exact OEM replacement is required or desired. Poly-Armour® lines and tubing meet the following specifications:
SAEJ527b
GM123M
SAEJ1290
DIN 74234
AGS Company - Poly Armour I tried to copy & paste the drawing on their page but couldn't get it done so I posted the link if you wanted to see what they are talking about. Thanks for your help!!
SAEJ527b
GM123M
SAEJ1290
DIN 74234
Well the Poly-Armour® is good stuff when it comes to brakes but I would NOT use it for fuel line in the tank. I would stick to S.S. for the fuel line in the tank.
I myself used Strickly Diesels Driven Diesel Fuel Tank / Pre-Pump Kit it cost a few more $$ than if I pieced it together myself. But when you think about the time you would spent and the fuel to get all the parts it is well worth it. It is a very nice kit comes with everything you need.
I wouldn't go out of my way to use it but I have coated line in mine, good after one year. At the time a couple of others chimed in, some concerns but no body had any actual problems. You might try ebay for ss tubing. I couldn't find anything local, at least that would sell me less than 10ft.
I am seriously considering putting a spin on filter to replace the little in line, so buying the kit with everything isn't a bad idea.
There were some great threads around last December, check those out.
unless you dont know what do get, gathering the parts is no big deal.
Wix Filters & NapaGold Filters: FleetFilter Secure Online Store filter and base from then.
Then while waiting for shipment, download the guzzle "in-tank" mod, and studay it. No different then studying the instruction sheet you'll get, from some high price kit
Hit up homedepot for the barb fitting you'll need for off the filter base, along with the 3/8 and 5/16 compression unions.
On way back, stop at any auto store for your "BASIC" fuel line 3/8 in size
Now, you find a hobby store, and buy a ft of each, 3/8 and 5/16 aluminum tubing...
Your ready now to build ur in-tank system..and at the price of about 40 buks.
To add just like for nappa - only pvf line at everything.
Here is was I used. Got these links from a fellow user when I went to do mine. All Stainless, the 3/8 was kinda a bear to bend but got it after a couple try's.
https://www.amazon.com/gp/product/B004XN8WLY
https://www.amazon.com/gp/product/B004XN8BZG
I don't see a problem with using brake line for external fuel lines.
As for in the tank, the PVF coating is on the outside of the line, so its a matter of whether or not it is safe/compatible with immersion in diesel.
According to this link: PVC (Polyvinyl chloride) Chemical Compatibility Chart
Diesel has an excellent rating with PVF, so it should be ok. However, since diesel fuel tanks like to collect water at the bottom, the line may eventually rust out (from the inside, and/or at cut ends/scratches where the PVF coating has been compromised). So, given the relatively small amount needed, I would just find/buy SS.
Also, as a side note, NEVER use the cooper alloy brake lines for fuel. They're handy for making easy bends w/o kinking, and they are fine for brakes. However, ethanol, in gasoline, will quickly corrode the copper lines from the inside out, carrying all kinds of garbage into the fuel system before leaking. Copper and diesel also do not mix well, causing bad "ju-ju". http://www.bp.com/content/dam/bp-cou...age-diesel.pdf
I did my in-tank mods 9yrs ago and used regular brake line and recently dropped the tank to replace a faulty sending unit. No Rust, No missing parts, No weird looking line.... All looked just like it did when i installed it.
I don't think Diesel fuel is going to harm it... not in my trucks lifetime, anyway.
