I`m glad that we didn`t get rain as the temperature dropped last night down to minus 6, it would be a mess. No sign of an early spring, it`s back to winter here.
A good idea to get the tires delivered to the tire shop rather than you having to lug them around John.
Good day Grant, hope the trucking business has picked up. I`m not sure about around here, things seem to be moving slowly.
Fresh donuts and coffee always hit the spot for me.
Tires didn't show again so a tracer has been put on them...
I still have a bit of work to do on it Colin but only have the exhaust to do and thinking of buying a kit and welding it up myself..
is that an aluminum exhaust system Colin or aluminized?
It would probably be aluminized. We used to use it when I worked at Speedy Muffler. It welded Nice with a torch (mig welders were rare then) and lasted much longer than regular steel pipe. I will be using aluminized on mine.
