Blue smoke
Old Jan 1, 2017 | 02:24 PM
VT tree grower's Avatar
VT tree grower
Blue smoke
My 93 7.3 idi only has 45K original miles (not a misprint), but emits too much blue smoke. It burns less than a qt of oil per thousand miles. I did a search on this forum, and valve seals were suggested as a likely problem. I haven't done a compression or leak-down test.
My car mechanic said there is a fuel additive designed to counteract a diesel's blue smoke, but that sounds too easy.
Any thoughts?
Old Jan 1, 2017 | 03:00 PM
Robert Long's Avatar
Robert Long
Blue smoke mostly caused by Worn valve guides, or seals
Cylinder &/or piston ring wear
Cylinder glaze
Piston ring sticking
Incorrect grade of oil.. Too thin and getting past rings, or valve guides
Fuel dilution of the oil, making it too thin.
Old Jan 1, 2017 | 03:32 PM
nova801428's Avatar
nova801428
Sounds like a bad set of injectors to me. Also could be a blown turbo oil seal.
klle5
Jun 4, 2016 12:15 PM
05F250DSL
May 18, 2015 04:34 PM
j tate
Nov 28, 2006 11:36 PM
Superunknown98
1983 - 2012 Ranger & B-Series
Sep 18, 2003 06:58 PM
jhdaniels
May 23, 2003 11:07 AM
