Weird ICP voltage issue
It's not the ICP sensor keeping it from starting. Air test it.
You even told me if I wasn't getting .24 or so at KOEO, the sensor was bad.
I'm not blaming the lack of start on the ICP sensor, simply working 2 issues at the same time.
What I am trying to say is, does oil at the ICP stay there, meaning the sensor will read some sort of number because there is some kind of pressure? It seems that everything I have read about the ICP V reading at KOEO "should" show .18-.24 with a healthy high pressure oil system.
EDIT to add: So you "could" be getting an accurate reading with the ICP at that low of voltage because your pressure is that bad? Meaning a leak somewhere.
Anyone able to understand or am I way off?
So bottom line is he needs to get the high pressure oil system air tested and go from there. Once that's resolved the ICP V is a moot point.
The sensor reports voltage and the PCM uses that as a reply. The throttle is opened and the PCM see's that, sends a command to say, I need this much pressure (ICP). IPR responds with a percentage of fluid. That fluid is 4000 psi from the pump, it makes constant pressure from the first crank of the key to the end, could be a little less or more, but high pressure non-the same. Fluid is sent to injectors and the response from the system (ICPV) is a reading in actual pressure.... this is what you sent. If its not enough for the demand, it sends more. All the while checking the voltage against reference voltage 5.0v for comparison. 5.0v=4000psi and as Mark posted (Bismic).
If the ICPV isn't correct, the truck will not run correctly, sounds simple. But without the right voltages, it won't start. It will run without the sensor using default values. But if the numbers are not correct, it's better to fix the issue correctly, the truck will run better with a good sensor.
You replaced the sensor and pigtail, no change... ment that it was pressure failing not the ICP itself or the connector. At that point it's an air test to find why the pumps discharge isn't making the loop... pump, STC, branch tubes, stand pipes, oil rail, injectors and back to the filter for cleaning and cooling and into the reservoir.
There is some residual pressure after the pumps shut down, no air... like holding you finger over the straw. If it all leaked back to the reservoir, you'll crank and crank and crank... finally filling the system with fluid and eventually starting the truck.
Unless there is a leak and the ICPV never sent the voltage back to say I have enough or there actually isn't enough pressure to start the truck. It reads .18-.24 with a properly functioning sensor... that's it. As pressure goes up, so does the reading until max voltage, 5.0v = 4000psi.
Yours never moved off of .07, kind of different. But in prospective looking back from the post by Bismic.
Hope this helps, all that I'm trying to do.
I am running an 03-04 sensor in my 06, and have been for quite awhile. I have not experienced any performance issues (can't say for sure it helped either). Reason for posting is that the sensor calibration can be off slightly and it won't hurt.
I very much appreciate all the assistance given, without it I would be lost.
