Ficm code
Old Dec 28, 2016 | 05:38 PM
Stoneburg86's Avatar
Stoneburg86
Ficm code
I replaced injector couple weeks ago. I hooked up to livelink thru sct because it was throwing a low voltage for ficm code. It is staying at 48 volts tho. I don't see any voltage from my glow plug relay, and I have a low voltage for my egr valve. Is it just bad luck that everything broke at once or is there a fuse or a connector that I forgot to plug in any help would be appreciated thanks
Old Dec 28, 2016 | 08:05 PM
navistarnut's Avatar
navistarnut
Does the truck run? If so running ok?
Old Dec 28, 2016 | 08:10 PM
Irish19614x4's Avatar
Irish19614x4
Wanted to say this earlier but stupid computer wouldn't let me respond. I agree though if it's running fine perhaps leave it alone. Unless it's doing something out of the ordinary.
48v on FICM is perfect so nothing to be worried there unless it's dipping. Not sure about the other measurement your asking about.
Old Dec 28, 2016 | 08:18 PM
Stoneburg86
Yes it's running and seems to be running ok. The po611 ficm performance code is what worried me because I don't want that to burn up my injectors. It smokes when I cold start it, so I thought maybe check glow plug volts and it's not reading on live scan. Is there a simple way to test the relay ?
Old Dec 28, 2016 | 08:48 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
If you've got a 611 code on a non-voltage modified FICM, you have a FICM issue. If your voltage is solid (and it sounds like it is), it may be that the issue is with the logic side of the unit.
We've never seen a bad FICM relay be the culprit for a 611 code, though have seen bad relays kill FICM's (meaning that it is a good idea to just replace the silly thing every 100k for good measure.
They are available on our site at FORD OEM 6.0L V8 FICM Relay.
If you wanted to resolve your FICM issue, we could either set you up with a unit on exchange or could repair yours.
Regardless of which path you elect, just remember that FICM's never die - they are always killed. As such, I'd strongly suggest pulling your alternator and batteries and having them load tested on a bench at the local auto parts store.
Hope this helps!
Old Jan 2, 2017 | 10:18 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Why not swap it with the cooling fan relay first to see if it works better? Aren't they the exact same P/N?
Old Jan 3, 2017 | 02:38 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Just for future information.... they can be swapped, right?
Old Jan 3, 2017 | 03:13 PM
Stoneburg86
Would a bad glow plug relay make the ficm dip in volts on a cold start? If so wouldn't a bad glow plug relay throw a code?
Old Jan 3, 2017 | 04:00 PM
WatsonR's Avatar
WatsonR
Low voltage inputs from the battery make glow plugs and FICM have low voltage inputs. Different codes for each.
Maybe you have a battery going down or the alternator going south.
Old Jan 3, 2017 | 04:34 PM
Stoneburg86
Isn't there different codes for low input voltage to ficm tho
Old Jan 3, 2017 | 05:17 PM
WatsonR's Avatar
WatsonR
Maybe for less than 8.5v... let it get that low and it's dead. You need to have a gauge for real time monitoring.
clintusaf
19
Jun 16, 2014 09:29 PM
sand_fiend
Dec 15, 2012 11:16 PM
White 99
Mar 16, 2010 12:29 AM
overtime_ranchero
Jun 3, 2004 09:58 AM
probablecause
Mar 26, 2004 03:55 PM
