1978 - 1996 Big Bronco
ecu help!
Old Dec 28, 2016 | 05:18 PM
Luke Guihan's Avatar
Luke Guihan
ecu help!
hello, 1994 bronco witha 5.0 to 5.8 swap from previous owner. the ecu is the suspect on a diag. its shutting the engine off when a test light was hooked up and a code was told that a ground in the ecu was gone. my question is do i get a 5.0 or 5.8 ecu or it does not matter? thanks so much this is driving me nuts!!
Old Dec 28, 2016 | 07:27 PM
Bubba Jones's Avatar
Bubba Jones
If you have the 5.8 engine in the truck, you'll need to get the 5.8 computer. The previous owner most likely had a 5.8 computer in there but I suppose it's possible he could have have the 5.0 computer tuned to run the 5.8. However, tuning that would be way too much money and effort. Probably quite a bit more expensive than just getting a 5.8 computer. If there are any identification numbers on the computer, you should be able to look it up and see what motor it is for.
So yeah, if you know it's a 5.8 motor, look for a 5.8 computer to get!
Old Dec 29, 2016 | 06:39 PM
Black Ford XLT's Avatar
Black Ford XLT
I am sure if it is still on the truck there is a white tag near the door hinges that gives the original computer info. Also you can use the vin number to code what engine. Since it was swapped to a 5.0 Rock auto sells them and BEWARE!!!!!!! if you use one from a salvage yard, check the capacitors for CORRISION. They have cause many of us grief including myself.Good luck TR
Old Dec 30, 2016 | 07:11 AM
rla2005's Avatar
rla2005
A 5L MAF computer will run a stock 5.8L engine just fine. If you are getting a new computer I would source one designed for a 5.8L as my first choice, but that's just me..
Green Griffin 420
21
May 29, 2014 03:56 PM
Trevor1
29
Nov 19, 2008 10:53 PM
chloichina
Computer Chips & Tuners
Nov 13, 2007 12:45 PM
msautry
Nov 18, 2003 12:08 PM
gquinn8516
May 31, 2003 04:51 PM
