Rebuilt Steering column replacement
Old Dec 27, 2016 | 09:35 PM
JefflovesF250s's Avatar
JefflovesF250s
All: Many years after removing the steering column in my '66F250, with a COM auto tranny, and having rebuilt and reassembled it, I can't recall how to fit it back into the cab. I tried today and I can't get enough angle on the assembly to get the shifter connection thru the hole in the firewall.
I have already installed a power steering box on the frame and the rag joint is in place.
What part of the re-assembly process am I missing or not doing?
Thanks Jeff
Old Dec 28, 2016 | 12:48 PM
TA455HO's Avatar
TA455HO
Lead Gopher
When I do mine I think I'm going to install just the outer tube through the firewall and then assemble it in place.
There is a way to do it. Don used to remove these intact. But he said it was a pain and you had to maneuver it just so.
The shift lever on mine had broke off and I didn't want to remove the turn signal lever and it still took a bit of doing.
Good luck!
Old Dec 29, 2016 | 10:47 AM
JefflovesF250s
All: Any thoughts on the process for replacing a rebuilt steering column? Jeff
appster99
Aug 29, 2017 06:57 PM
rusty d shackleford
51
Jun 21, 2012 08:43 PM
Layne
Nov 17, 2011 08:57 PM
gtex
Mar 31, 2003 09:19 PM
