Short block Interchangeability ??
Aug 26, 2003 | 05:39 PM
Not sure what I'm gonna do yet with my noisy 300. It's got a Collapsed Lifter and Low Oil Pressure.
I'm debating replacing the short block with on out of 78 F150.
Are there any issues I need to be aware of if swapping shortblocks between model years ??
Aug 29, 2003 | 07:10 PM
I've heard there are (3) different 300 blocks out there.
Does anyone know what the difference(s) are ??
I know starting in 87, Ford went to EFI and the fuel pump boss is NOT machined out.... What about other differences ??
Can I use a mid-70s 300 Shortblock with my 87 Head and EFI stuff ??
Aug 30, 2003 | 01:55 AM
Is this true ??
I know there is a difference between the Carbed and EFI blocks (No fuel pump hole on the EFI).
How about other differences ??
Can I use a mid-70s 300 shortblock with my 87 EFI head/manifolds ??
Aug 30, 2003 | 06:38 PM
I do not see any reason you can't do it. You can use a 240 bloce too, just change out the rods and pistons. The 240 just has a longer stroke.
Aug 30, 2003 | 06:39 PM
Sorry, I meant to say, the 300 has a longer stroke!
Sep 1, 2003 | 01:49 AM
I've been researching Engine rebuild Kits for my 87, and I'm coming across ALOT of them ending with the 86 model year.
Other than going to EFI (fuel pump boss not drilled out) what other difference(s) are there to the block ???
vettman
Jul 24, 2011 12:40 PM
ladelld33
18
Jun 11, 2010 09:34 PM
fairlaniac
4 Cylinder Engines
Jul 14, 2008 11:25 PM
AXE168
Apr 14, 2006 01:38 PM
rhetor
Sep 5, 2003 07:01 PM
