If its your desire to save money when you build your 390. Use the 352 block as it is the same bore and block casting as the 390, then buy a 390 kit, a set of 390 rods, and a 390 crank. All of these parts are available through most local auto parts stores as reconditioned parts. Be careful to determine what the bore of the cylinders before ordering your kit. The bore can be determined by your local machine shop.
Nope, that is incorrect. The 352 bore is 4.00 where the 360/390 are 4.05. Now of course you can have a 352 block bored to 4.05, then go buy up 390 parts..
