Weird transmission problem.
Old Dec 27, 2016 | 04:56 PM
hellssorrow's Avatar
hellssorrow
Hey guys. I bought late 98 F-250, 5.4 G, 4WD. Only spent $300 to get the truck. Had to replace the steering flange because they messed up the ignition cylinder and flange. Truck didn't run for 4 years. 249K miles, no history available. Got the engine running, no DTCs. D, 3, 2, 1 barely moved the truck forward but, R hauled butt in reverse. Checked transmission fluid it was good and clean. Came back to it a few days later it threw a P0720 (output speed sensor circuit) and I have no reverse, park feels like it wants to move, R is neutral, N is forward, D is forward, 3 is forward, 2 is forward, 1 is forward. The N is full drive. I cleared the P0720 code after it came up and it has not returned. The instrument gauges work but the odometer display is intermittent. What is your guys opinions? Linkage? Fluid? Sensor? Wires?
Old Dec 27, 2016 | 09:12 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by hellssorrow
I have no reverse,park feels like it wants to move, R is neutral, N is forward, D is forward, 3 is forward, 2 is forward, 1 is forward. The N is full drive.
The linkage appears to be one position out of adjustment.
But this is a very unusual truck. I've never seen a '98 F-Series with D, 3, 2, and 1. That's one more position than Ford built.
Old Dec 27, 2016 | 10:38 PM
hellssorrow
It's a Canadian Ford. F-250 non-super 7 lug hubs. When I had the locksmith program the new keys he stated he never seen a 98-99 f250 non super that had the Ford PATS in it. I'll double check the transmission for a model number and the instrument cluster for the gear range. I could be mistaken about 3rd, but I seem to want to recall seeing it when I was working on it late Saturday night.
Old Dec 28, 2016 | 08:05 AM
Mark Kovalsky
If it has D-3-2-1 it's the only one built like that. Ford built them with D-2-1. To get 3 you press the OD OFF button.
Old Dec 28, 2016 | 05:50 PM
hellssorrow
Sorry, Mark you are correct. D, 2, 1. I'm too tire as of late to really be working on this. I'll find the linkage adjustment instructions. Thank you Mark.
GabezF250
50
May 2, 2025 02:33 PM
fuelsmoke1
Aug 8, 2019 05:20 PM
Coronado
6.2L V8
Jul 15, 2015 07:56 PM
Walwal44
Feb 2, 2015 05:12 AM
bakos
May 16, 2013 08:13 AM
