No smog pump
Old Dec 27, 2016 | 11:24 AM
82fordowner's Avatar
82fordowner
No smog pump
Ok so my question is, on my 1982 Ford F100 Stepside 4.9 300-6cyl. It is missing the smog pump, it was like that when I got the truck and I have never replaced it. So how much will that effect my carbulation? Does my carb need readjusted to make up for no smog pump? It doesn't seem to be running bad, but I do get terrible gas mileage. Does this effect my gas mileage? And is there a certain adjustment the carb should be at because it is missing the pump. Any help will be apparicated thanks. Fred
Old Dec 27, 2016 | 11:57 AM
kh0432's Avatar
kh0432
The smog pump injects air into the exhaust and has no effect on the carburetor. You won't get good fuel economy on an 82 vehicle.
Old Dec 27, 2016 | 12:02 PM
Brnfree's Avatar
Brnfree
Not 100% about your I6 but generally the smog pump only adds extra air to the exhaust so it has no effect on your tuning or intake mixture.
There are a lot of posts here about maximizing I6 fuel economy and most of those posts start by confirming whether you have a hacked up and confused computer controlled system or a non-computer controlled fully adjustable carb and Dura-spark ignition system.
If you've got a hacked up and confused computer controlled system it will be in limp mode and power and mileage will be poor.
Look at the distributor for a clue. IF it has vacuum advance its most likely a Dura-spark distributor. But if it does not have a vacuum advance then you very likely have a lost and confused computer holding you back.
Old Dec 27, 2016 | 01:10 PM
Franklin2's Avatar
Franklin2
82 I6 should not have computer control.
Old Dec 27, 2016 | 01:15 PM
ctubutis's Avatar
ctubutis
Unless it was built for sale in California in which case it'll have the EEC-III ignition/carburetion system.
Old Dec 27, 2016 | 02:04 PM
82fordowner
Thanks everyone I believe I have the answer I need. Thank you all
Old Dec 27, 2016 | 05:27 PM
Franklin2's Avatar
Franklin2
Thanks for the correction.
boothead
Jun 21, 2017 05:18 PM
MrFord619
Nov 14, 2016 09:57 AM
scooter1986
Dec 19, 2005 08:58 AM
scottddove
Oct 8, 2005 10:00 PM
az_ford_man
Bronco II
Apr 21, 2003 02:57 AM
