which smog pump?
Old Dec 14, 2005 | 07:09 PM
scooter1986's Avatar
scooter1986
which smog pump?
i have an 85 f150 w/ carb and the gay computer thing that controls timing...when i bought my truck it had no smog pump but i want to put one on...advance says that there are 2 possibilities...how do i know which one goes on my truck w/o the old smog pump?
_Scooter_
Old Dec 15, 2005 | 10:22 AM
Franklin2's Avatar
Franklin2
If you go to www.partsamerica.com(the advance site) and plug in your truck, you can see the difference in the pumps. I think the difference is the way the plumbing hooks up to the back of the pump.
Old Dec 15, 2005 | 12:16 PM
Icicle's Avatar
Icicle
I have one laying on the ground by the garage door you can have......
Old Dec 16, 2005 | 09:58 AM
johnsonswamp's Avatar
johnsonswamp
Same here, I have pretty much everything to do with the smog mess for a 351 if you need anything.
Old Dec 16, 2005 | 10:27 AM
Sycostang67's Avatar
Sycostang67
Consider yourself lucky you only need one, my truck uses both!
Old Dec 18, 2005 | 05:18 PM
scooter1986
how is that possible?
Old Dec 18, 2005 | 05:25 PM
scooter1986
what SHOULD my truck have to be running properly after the smog equipment was removed?
Old Dec 19, 2005 | 08:58 AM
Sycostang67
On trucks with a GVW of #8500 or more, no catalyctic converter is required, I guess they compensated by throwing on an extra pump.
I would go to the junkyard and see if you can find a truck like yours to look at, at see which pump it has. Does the store have them in stock, or is it a special order item. If it's in stock, can't you just take it out to your truck and compare real quick?
