General Automotive Discussion
85 Chevy tk hydroboost
Old Dec 27, 2016 | 01:27 AM
SShank42's Avatar
SShank42
85 Chevy 1 ton 4x4 diesel. The brake pedal is hard to push. The brakes will stop, but to me it takes to much push effort. I replaced the hydroboost. Did not change the problem. What should be my next step? Power steering pump, proportioning valve, rubber brake lines, master cylinder?
Old Dec 27, 2016 | 04:08 PM
Ford_Six's Avatar
Ford_Six
How's the steering? Does the effort change with pressing the brake pedal? If the steering is hard as well, then the pump is not producing sufficient flow to run the system.
Old Dec 27, 2016 | 09:44 PM
SShank42's Avatar
SShank42
Steering is pretty good. If off road it gets a little more difficult to turn the wheel. If I blip the throttle while turning it helps make it turn easier.
smartken22
6.4L Power Stroke Diesel
Jun 18, 2020 08:07 AM
swamp donk
Aug 1, 2017 08:10 PM
stroker870
Feb 24, 2014 10:17 AM
bonesbut
Oct 21, 2006 01:59 PM
groundcontrol
Apr 7, 2004 09:03 AM
