OMG - this is frustrating...
If you want to run something inside the cab the pass through wires are your best bet just pick an upfitter wire on the driver's side then attach a wire to that one and to the pass through then to the equipment you want to run on the inside of the cab.
not really any need to run extra wires through the fire wall.
No relay is needed when using the upfitter switches they already have relays.
Here is a picture of the final install and a video clip of it in action.
Link to Video Clip:
DashCam Video Clip - Example
Thanks for the help guys!
Link to Video Clip:
I appreciate the tips from archer3 for the top on removing the fuse box above the UpFitter Switch wires. Helped a ton!
Like others here I'm still learning so a little knowledge from those who've figured out things or acquired knowledge of how things work helps immensely and saves a lot of headaches too.
Thanks to all of you members who pass their knowledge.
Robert6401
15
10-02-2007 07:26 PM
