Posi diffential swap
Old Dec 25, 2016 | 12:54 PM
Nathan511's Avatar
Nathan511
I have a 95 f150 4x4 and I believe I have either open or limited slip differential in it. I want to swap it for a posi rear. Any brands or specific set ups I should look at? Not looking to spend a fortune either so looking for some advice.
Old Dec 25, 2016 | 03:06 PM
meborder's Avatar
meborder
Powertrax is the first thing that comes to mind.
https://www.powertrax.com/
Change from open or l/s to locker without having to change clearance settings. The cost is usually pretty attractive, too.
Old Dec 25, 2016 | 05:27 PM
Nathan511's Avatar
Nathan511
how do I know which one I need to buy? Is there an easy way or do I have to take the axles out and count the splines?
Old Dec 25, 2016 | 06:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If your truck has Limited Slip (posi or posi-traction are a GM terms), the AXLE code printed on the Certification Label will begin with a letter.
But, if the AXLE code begins with a number: No Limited Slip.
jcgooden
Oct 5, 2011 06:58 PM
wotan
18
Aug 25, 2011 10:22 AM
richdawg
Mar 10, 2009 06:20 AM
stephen.south
24
Mar 5, 2009 07:02 PM
Fordman_Evs
May 25, 2006 10:31 PM
