Limited Slip
Old Mar 2, 2009 | 03:33 PM
stephen.south's Avatar
stephen.south
Limited Slip
Did any of our trucks (or older) come with a Limited Slip in the Sterling 10.25?
I've been looking to get one from a junkyard donor and can't find any. I really don't want to spend the $500 + for a new one.
Old Mar 2, 2009 | 03:53 PM
phillips91's Avatar
phillips91
yes. for the 4.10, if i remember correctly, you need to be looking for axle code c5.
Old Mar 2, 2009 | 04:27 PM
tjbeggs's Avatar
tjbeggs
Yes both the 4.10 and 3.55 can have LS. like Phillips said the C5 and also C9 axle codes are limited slip.
Old Mar 2, 2009 | 07:00 PM
c00nhunterjoe's Avatar
c00nhunterjoe
get a carrier out of a superduty, the 10.5 is a direct swap and has a monster posi in it.
Old Mar 3, 2009 | 06:43 AM
Neal 97 250's Avatar
Neal 97 250
Is the SD a true posi or a LS
Old Mar 3, 2009 | 07:03 AM
phillips91's Avatar
phillips91
the axle tag on mine says 4.10 LS and its a 2000 model. not sure on the newer ones though.
Old Mar 3, 2009 | 04:45 PM
Diesel_Dirk's Avatar
Diesel_Dirk
IIRC Positraction is a GM brand name.
Limited slip is the generic term for traction adding differentials.
If you rear axle is open, a LS will make a huge difference. My '87 dually has one and my '97 SRW doesn't. The '97 barely move in 2wd on ice or snow, while the '87 will go nearly as far in 2wd as the '97 will in 4wd.
Old Mar 3, 2009 | 06:37 PM
foxracing0934's Avatar
foxracing0934
I feel like the LS in my truck works much better than my dads 6.blow which is a LS 3.73. Whenever I do a burnout it's two wheels no matter what the road conditions or road angle or whatever. But with his is a crap shoot whether it with be a one wheel peeler or actually be a LS system.
Old Mar 3, 2009 | 07:37 PM
c00nhunterjoe
the disc brake rear's are harder on the limited slip during burnouts then the drum brakes are. its easier to overcome their holding force then the disc's. look at a diagram of the internal's of the 10.25 ls and the 10.5 ls. the physical weight alone is ridiculous. i would bet the 10.5 carrier is 30 pounds heavier then the 10.25 carrier and if i recall it has twice the clutches.
and yes, "positraction" is a GM name just like "hemi" belongs to chrysler...... even though ford and chevy have had "hemi" headed engines they are not advertised as such.
the same goes for rear's. they are all "limited slip's". GM calls theirs positraction while dodge's was the sure grip, and ford uses a traction lock.
Old Mar 3, 2009 | 07:45 PM
foxracing0934
Ahh I see, that makes perfect sense. So does that mean that when I do a rear disk conversion i'm going to become a one wheeler peeler? Cuz that would be a huge draw back.
Old Mar 3, 2009 | 07:50 PM
tjbeggs's Avatar
tjbeggs
It might be a draw back for burn outs but launching in 4wd you can now build 20+ PSI boost and still hold it back to launch.....Ask me how I know.....
Old Mar 3, 2009 | 08:52 PM
foxracing0934
That is a good point, I like racing as much as doing burnouts. How easy is it to hook up a line lock to the front brakes. Then I would even have to burn up my shoes or eventually pads in the rear
Old Mar 3, 2009 | 10:12 PM
c00nhunterjoe
i can still burn both tires in my truck with the disc's via powerbraking but i prefer to save my rubber, its expensive to replace, i spin in the rain and mud and occasionally the snow when we get it. dry pavement is too hard on the tires
Old Mar 4, 2009 | 05:54 AM
Cuda_jim's Avatar
Cuda_jim
If you are changing to rear discs then throw on an adjustable proportioning valve in the rear. Line locks are electronic, Prop valves are hydraulic. I like the 'lever' style better than the '****'...it's much faster to adjust. Be sure to turn the rears on before you launch.....did that once at the track....really hard to stop w/o rear brakes at 140+ MPH (Cuda not my truck LOL)
Adjustable Prop Valve
Old Mar 4, 2009 | 10:11 AM
cowmilker08's Avatar
cowmilker08
is it possible for limited slip rearends to wear out?
in the mud or snow i spin both rears but the few times i've done burnouts on the road
they are one wheel peels. Just curious, i'm not even sure of the code on the axle, and
can't check since truck is still at the shop getting tranny built.
Side Question: What ford engines were ''hemi's?''
