Differential swap?
Old Oct 5, 2011 | 12:45 PM
jcgooden's Avatar
jcgooden
Differential swap?
I have a F150 with axle code 19, which means, I believe, that i have a 3.55 non-limited slip differential. Is there any way I could put in a posi or limited slip dif or would I have to do a whole axle swap?
Old Oct 5, 2011 | 01:21 PM
kedwinh's Avatar
kedwinh
They make Limited slips and lockers for almost all axle types, so yes you can add one to yours. But it would probably be cheaper in the long run if you could find a good used one already setup that way. A limited slip will cost you around $300 and up depending on which one you chose. Then you'll need an install kit and someone to install it if you don't know how which will probably be another $250 or up.
Old Oct 5, 2011 | 06:58 PM
jcgooden's Avatar
jcgooden
Thanks bud
Cfrank89
Nov 5, 2017 07:51 PM
Nathan511
Dec 25, 2016 06:14 PM
Pappawheely
Jan 29, 2016 11:53 AM
ol'chebby
Oct 23, 2012 04:45 AM
stephen.south
24
Mar 5, 2009 07:02 PM
