8-ball
Old Dec 23, 2016 | 12:16 PM
N2S3's Avatar
N2S3
8-ball
can anyone give me an hint what is the thread on the shifting lever (1977 F150 auto), if one wants to mount an 8-ball...
there are smaller bowls with 50mm or 38mm instead the 57mm bowl.
Old Dec 23, 2016 | 12:52 PM
meangreen92's Avatar
meangreen92
There is no thread if it's column shift. The factory handle end is glued or press fit onto the arm. The bare arm, with the end removed, will just have splines or knurling.
Old Dec 23, 2016 | 01:07 PM
mountain dewd's Avatar
mountain dewd
Yep. A simple tap/die job will solve that though.
Old Dec 23, 2016 | 01:19 PM
HIO Silver's Avatar
HIO Silver
Just something to think about...
if the shifter detents have too much slop the weight of a billiard ball could inadvertently shift the trans if ya hit a large bump or dip.
Old Dec 23, 2016 | 02:14 PM
N2S3's Avatar
N2S3
good point, should mount the 38mm
Old Dec 23, 2016 | 02:42 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The **** end is a little cut off in the picture, but this is what you'll find when you remove the ****.
EDIT: Replaced original picture with a better one.
Old Dec 23, 2016 | 03:16 PM
mountain dewd
For my money I would slip a .50 BMG casing over and call it good.
FordFlare
Jul 12, 2015 08:27 AM
ADOR
Aug 18, 2014 06:39 PM
teardropty
13
Jun 30, 2011 08:21 PM
dawfun
Aug 30, 2010 01:08 AM
Customcab
May 6, 2004 07:42 AM
