Spongy/Slow Throttle Response
Old Dec 23, 2016 | 10:03 AM
Nathan Murphy's Avatar
Nathan Murphy
Hello everyone! First post here. I am a dedicated Ford truck owner. Both vehicles I have had are both F150's. My first one was a 5.4L v8 03 and my current is a 5.4L v8 06 4x4, seen below.
When I bought the truck it was straight piped. I went ahead and did a GOTTS mod on it. The truck also has the factory tow package. I replaced the spark plugs and engine oil (Amsoil High Mileage). I did a couple basic things like putting in the lightbar and replacing the headlight housings. Other than that it it pretty much the same as when I bought it. I cleaned the throttle body and sensors, using the proper cleaners. I ran two cans of SeaFoam through as well.
With my last truck, I 'flushed' the transmission (not a actual flush, but I changed the tranny oil about 7 times in a short period of time). A buddy suggested I do it, as it was a DOT truck and maybe wasn't treated the best. It was a automatic, just like my 06. Would that do any actual good?
Ok onto the point of this post. I have noticed that truck has a spongy/delayed throttle response. The engine idles normally and there are no codes being thrown. I had a similiar issue with my 03 but it had a cable to the pedal and I just had to tighten that up and it was better. Perhaps because of the straight pipe and GOTTS and no tune?
I appreciate any feedback!! Thanks!!
Old Dec 25, 2016 | 02:01 PM
EBC-150's Avatar
EBC-150
Do a google search for: 'diamond bird mod f150'
Old Dec 25, 2016 | 04:59 PM
Nathan Murphy
I will check it out. Thanks!
Old Dec 26, 2016 | 02:26 PM
Nathan Murphy
I checked out the diamond mod and that didn't do anything for me. I get 75.7% for a throttle position. Is that normal?
Thanks!
Old Dec 26, 2016 | 03:37 PM
EBC-150's Avatar
EBC-150
No, I get 100%. You might need to recalibrate the throttle pedal, did you read and follow that procedure?
Old Dec 26, 2016 | 03:51 PM
Nathan Murphy
I did this:
1. Turn the key to the On position and wait till the lights on the dash come on.
2. Slowly push down the gas pedal completely, then release it as quickly as possible.
3. Turn the key to the off position.
4. Repeat 3 - 4 times.
That is the reset that I kept seeing on the forum posts talking about the diamond mod.
Old Dec 26, 2016 | 08:06 PM
FlyingAl's Avatar
FlyingAl
My 5.4 got pretty sluggish when the cats clogged up somewhere around 400k miles. New cats and everything was fine.
Old Dec 26, 2016 | 08:13 PM
Nathan Murphy
I will check into it. I am only at 200k right now, but I do know that they truck was used in construction and for some heavy towing in its past life. It does have the tow package on it though.
Thanks!
-Nathan
Old Apr 22, 2017 | 12:05 AM
Bruce Cook's Avatar
Bruce Cook
Same problem different year
Thanks!
-Nathan
I have a 1997 f150 4x4 xlt with a 4.6, it won't burn rubber unless wet and I slam it when I'm on the freeway I have to slam the pedal to pass cars, my truck is straight piped so it gets loud, if I'm rolling on freeway at 50-70 and lightly press pedal rpms go up a couple hundred then drop back unless I press harder then they shoot up to 3500 I get a burst of acceleration and then they go back down after I let off the gas not wanting to stay in that high of a rpm too long it's like I have to quickly press the pedal to get a quick response or it's sluggish takeoff
Old Jun 7, 2020 | 11:56 PM
Jonboy862's Avatar
Jonboy862
Diamond bird?
Thanks!
hey I’ve been reading these old threads. I’m a new member by the way, but I’ve been reading these threads and where y’all talking about diamond bird mod, I googled it. All that comes up is a link back to this very same post. Can someone enlighten me as to what that is? Or where I can find the info?
Strokin-A-2010
6.2L V8
Sep 30, 2024 11:43 AM
WarWagon85
Jun 28, 2017 09:09 AM
99F350PS
Escape & Escape Hybrid
Oct 19, 2013 10:18 AM
idealtrucks
2004 - 2008 F150
29
Dec 13, 2006 04:59 PM
DWMAC
Computer Chips & Tuners
Aug 6, 2002 05:23 PM
