hi Senix, how you been. I've been out there chasing gremlins and found my MC batteries with the nice green peep hole now have a sort of orange peep hole. Both of them. I know from hanging here and on of my other trucks that these batteries can do some strange stuff when they are going bad. Do you suppose that could be the problem? I will of course check the brake sensor also. Thanks for the help.
The initial post is not very clear. Is the problem your trailer brakes do not activate when you are stopping? And it has worked previously? And then it just stopped working? And you knew it was not working because?
Hey thank y'all. I posted it over on the 6.7 forum and boy am I embarrassed. That brake controller does not activate below 12 MPH or so. I'm checking it parked so of course I get nothing or at least very little. Sorry to waste your time.
That's what I was going for with my question asking how you knew it was not working. No need to be embarrassed. That comes up all the time. If you don't ask you don't learn!
it reduces output below 11 mph, but should at least show the connection and if you step on the brake pedal you should see a bit of movment on the the TBC output.
Steve
I suspected a trailer brake problem because my front brake pads wore out sooner than on any of my previous trucks. And I may or may not have one, I just can't prove it standing still because the Ford brake controller does not activate below 12 MPH. That's what I forgot. Just a brain cramp.
When I hook and before raising the trailer legs all the way up I always apply the brake controller to be sure that the 5th wheel jaws are actually locked and the trailer brakes always lock up. But i did notice that when pulling away and trying the brake controller it barely locks them up. I guess I learned something new today about the truck braking system.
I also do the same and hope everyone does a brake check before hitting the road.
Steve
Oh I'm never embarrassed because of something I don't know. I'm embarrassed about this because I've known this for some time and have even dealt with it once before. Just part of ageing. I'm pretty close to being able to hide my own Easter eggs, maybe next year.
