5th wheel puck/ring options
Old Jan 15, 2017 | 03:29 PM
G-Dad's Avatar
G-Dad
I had my F350 bed sprayed with Line-X by the dealer. I didn't figure out what they had done till months later when I got the instructions from this thread and tried to put the rings on correctly. Once I got the Line-X scraped out of the grooves, I was able to pretty much get the rings on by hand. Had to persuade a couple with a flat blade screwdriver; but, was actually pretty easy.
Old Jan 15, 2017 | 10:43 PM
WyoBull's Avatar
WyoBull
Well, today I followed the lead from you guys on this post and got my trim rings attached as they were meant to be.
I had a spray in Reflex liner done after I purchased my truck and they over sprayed on the 5th wheel and gooseneck mounts so I had to trim all that away which was a royal PITA!
After I got that all cleaned up I used my heat gun to heat up the trim rings so they were more pliable. I then semi inverted them and they popped nicely into place.
Thanks for the input guys, they are now solidly in place as they should be!
Old Jan 16, 2017 | 02:29 PM
G-Dad's Avatar
G-Dad
Beers all around 👍🍺
Old Jan 18, 2017 | 07:23 AM
Bear 1's Avatar
Bear 1
Thanks
Originally Posted by G-Dad
Beers all around 👍🍺
Thanks for the post. I haven't tackled mine yet.
Old Jan 18, 2017 | 08:04 AM
WyoBull's Avatar
WyoBull
Using a heat gun to make those rings a lot more pliable is the key. Had I not had to clean up a bunch of bedliner over spray on the hitch, it would have been about a 15 minute job.
Old Jan 27, 2017 | 12:38 PM
prm99v6's Avatar
prm99v6
As info.
Here is the part number from my Ford dealer. I just ordered it because the they weren't installed on the F450 I just got and only two were in the truck.
It is called a Hardware Kit and is supposed to include 4 rings and 4 plugs.
Part Number: BC3Z99000A25A
Old Jan 27, 2022 | 01:33 PM
powerscol's Avatar
powerscol
Question
I know this is an old thread, but has anyone been able to put the trim rings back after installing a BedRug or Bedrug impact mat? I was thinking I would need to shave down the mat thickness near the puck.
Anyone done this or seen any threads on what someone else did?
Thanks
Old Feb 5, 2022 | 07:00 AM
hondapro's Avatar
hondapro
I use a heat gun to help reinstall the outer ring
Cuw45
Modular V10 (6.8l)
Jun 3, 2014 08:45 AM
mxracer3276
Aug 8, 2009 05:25 PM
joe_13894
Mar 17, 2009 01:39 AM
mellojoe
Apr 2, 2007 02:25 PM
Seifferlein
Aug 17, 2004 11:48 PM
