Sponsored by: Real Truck
Not your normal towing thread...
Old Jan 26, 2012 | 11:06 PM
Psyclopse's Avatar
Psyclopse
I've looked around and haven't really found what I'm looking for. The subject is flat-towing a Super Duty and/or Excursion...
Looks like I'll be getting an Excursion pretty soon (well, I WILL be getting one- the "pretty soon" part is the maybe). I've already researched tow bars and mounts for these vehicles. My question is- what all am I looking at doing to prepare the TOWED vehicle for longer-distance towing? Preferably without having to dismantle anything or tearing anything up in the process. My goal would be to be able to tow one behind the other interchangeably with a tow bar across one or two states, then having the towed vehicle ready for use with as little fuss as possible once I got there.
The only experience I have with flat-towing with a tow bar is a CJ7 I used to have- but it didn't have a drivetrain or driveshafts when I towed it) and of course HMMWV's when I was in the Marines- which was military, so you just put the transfer case in neutral and rolled, no lights or anything.
Oh, and both trucks are 4x4, and both have electronic transfer cases (for now).
Old Jan 26, 2012 | 11:22 PM
Kajtek1's Avatar
Kajtek1
What you are trying to do is toad. Those issues are well covered on RV forum, where flat towing other vehicle behind motorhomes is standard issue.
Check if your truck is design to be towed. Some transfer cases allows to be shifted to N, some don't.
Other issue is safety and legality. Towing the same weight with no brakes is not too safe to start.
Toads are not trailers, therefore legally in most states don't have to have brakes, but not too many officials understand the murky laws.
To be safe I would add a brake system like BrakeBuddy or similar.
Tow bars are the easiest issue in all that mess.
Good luck with figuring it all out
Old Jan 27, 2012 | 06:56 AM
Skinsfan6's Avatar
Skinsfan6
Excursions do not have a ready neutral position for the transfer case. They were never made with a floor shifter for the transfer case, only the ESOF dial with no neutral position. I have also seen in my owner's manual that they are not to be towed (by a tow truck) with any wheels on the ground. Only a flatbed will ensure no damage to the drivetrain. So I am 99% sure you shouldn't two it in the manner you were planning on. Does the Excursion run? You might just need to find someone to drive it back.
Old Jan 27, 2012 | 07:09 AM
senix's Avatar
senix
With electonic transfer case you will have to pull the driveshafts.
Get a flatbed trailer and take it that way.
Old Jan 27, 2012 | 08:10 AM
Quad Racer's Avatar
Quad Racer
I wouldnt risk it. I'd either get a flat bed trailer, or driving it back would be an option but a ton of gas. Much better to even rent a trailer before gas bills.
Old Jan 27, 2012 | 08:48 AM
jh818's Avatar
jh818
...or you could do one of two things instead of towing if you're doing it alone:
1. If there's an airport nearby, get a round trip flight on Southwest or some other low cost carrier, fly to the city the other Excursion is, and drive it back. Use the return ticket on a future trip.
2. Rent a small car (one way) to the location of the other Excursion, return it there, and drive the Excursion back.
Both options allows you to get back home using the same mode of transportation if the deal doesn't pan out. If it pans out, you'll just drive the new Ex home.
Old Jan 27, 2012 | 08:49 AM
ruschejj's Avatar
ruschejj
Where are you towing it from? Where is it going?
Lots of folks out here and in my case I travel a lot. For example, I am in Fayetteville, ar right now and if you happen to be in little rock and need the ex towed to Birmingham, I could throw it in my trailer since I am going that way.
It's a long shot but you never know.....
And I would really hope that you decide to trailer it. It's the safest and best way to do what you need to do.
Old Jan 27, 2012 | 09:45 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Originally Posted by Psyclopse
My question is- what all am I looking at doing to prepare the TOWED vehicle for longer-distance towing? ...My goal would be to be able to tow one behind the other interchangeably with a tow bar across one or two states, then having the towed vehicle ready for use with as little fuss as possible once I got there
Maybe I'm reading his post weird, but I read it as he's planning on doing this more than once...why else would he make them interchangeable if it was for one pull home?
The only way I can think of to repeatedly get two functional Ex's across two states and have them both 100% ready to roll on arrival is either find a 2nd driver, have one pull a deckover with the other on it, or stack them both on a wedge.
Old Jan 27, 2012 | 12:29 PM
Kajtek1's Avatar
Kajtek1
Don't assume anything about the vehicle >>> contact manufacturer.
Electronic transfer case might have the option, but the option will not be listed in Owners Manual.
As a fact, I know that lot of people toad Hummers. Those have electronic case, where after pushing 2 buttons at certain sequence will put them in N.
Something somebody found from the manufacturer and now everybody interested is doing it.
Than you have systems that install driveshaft couplings with quick disconnect, but those cost pretty money.
Old Jan 27, 2012 | 06:57 PM
Psyclopse's Avatar
Psyclopse
I guess I didn't give enough information...
One truck is my 99 F250, the other will be an Excursion (01 if I get the one I'm looking at). The issue is NOT getting it home- it is local to me. Most trips would be from north-central Indiana to southern Kentuck and back, maybe a few to Wisconsin.
The Ex is a theft recovery vehicle that I will be playing with a little. I plan to replace the transfer with the non-electric one (current case is cracked). I plan to do the same later in the pickup. I haven't researched the braking subject yet, but it was probably going to be my next question (adding something to activate the towed vehicle's brakes). With the cases swapped to manual, would this still be doable, or no?
Old Jan 27, 2012 | 07:03 PM
senix's Avatar
senix
If you switch to manual transfer cases and manual hubs, put the truck/excursion in N and tranfer case in N and you go do it.
Old Jan 27, 2012 | 09:17 PM
Kajtek1's Avatar
Kajtek1
The toad brake systems are pretty available, but not cheap.
The most advertised is Brake Buddy, but overpriced IMHO. Do ebay search.
BrakeBuddy Vantage Select | BrakeBuddy - Braking systems for motorhomes towing a vehicle
bamacommander
2009 - 2014 F150
Oct 8, 2023 08:06 PM
oldboots1950
41
Sep 22, 2017 07:44 PM
rrthor
Oct 19, 2016 05:30 AM
et_miller_87
Jun 19, 2014 02:48 AM
mickelsons
Nov 29, 2007 02:10 AM
