Sponsored by: Real Truck
The Dreaded Wrench Disappeared!
Old Dec 19, 2016 | 06:12 PM
minke's Avatar
minke
Saturday, driving in ~6 inches of snow in 4WD at 40MPH at -4ºF we felt a large clunk. I don’t believe I hit anything. It sounded like it may have come from the transfer case but this is far from certain. I think that the cruise control was on but I’m not positive. The dreaded wrench appeared in the display and in a short while I noticed that the cruise control didn’t work.
70 miles later I parked and as a test re-started the engine. No bad symptoms. Later we drove home and all was well. Today I went to the near-by auto parts store and their scanner tool said no codes stored.
Is there anything I should check?? I have no idea of what happened.
Thanks.
note: ‘11 F-250 6.2L Supercab shortbed
Old Dec 19, 2016 | 07:13 PM
fordman19762003's Avatar
fordman19762003
If your cruise was on maybe you hit a slick spot causing the tires to spin until they hit a high traction spot which could cause a jolt when they hooked up. If there isn't a code stored I don't think there is anything you can do but drive it and see if it comes back.
Old Dec 19, 2016 | 07:26 PM
SHAWZER's Avatar
SHAWZER
My 2015 F 250 6.2 did the exact same thing 2 days ago . But my truck does not have cruise control . After restarting later wrench was gone .
Old Dec 19, 2016 | 08:16 PM
senix's Avatar
senix
the wrench is a powertrain fault.
It may have just resolved itself.
The code is likely still in the history.
I don't think I would be too concerned at this point unless it comes back.
Old Dec 20, 2016 | 06:03 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Weather.. ??
the computer sensed a Fault.. set the light..."wrench" over a period of time computer determined the fault is No longer valid... turned light off.
so WAIT and see. as for "Now".. no problem to fix.
Old Dec 20, 2016 | 11:55 AM
minke's Avatar
minke
Thanks all. I didn't think I was driving a time bomb but I really wanted the opinions of others who may know more than I do.
Again,,, thanks.
Old Dec 20, 2016 | 01:18 PM
Boaterguy's Avatar
Boaterguy
2 cents worth, never thought it was a good idea to use cruise in the snow to begin with.......
Old Dec 20, 2016 | 02:53 PM
minke's Avatar
minke
There is a lot to be said for prudence. OTOH you just get used to it and you can't avoid work for every snow.
Old Dec 20, 2016 | 03:01 PM
don123's Avatar
don123
I agree with you!
Old Dec 26, 2016 | 08:49 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
agree with Boaterguy
Old Dec 26, 2016 | 09:37 AM
5851a's Avatar
5851a
I've told the wife to not even use it in the rain. To many wallered out blacktops here from heavy truck traffic, gets you hydro planning in a hurry.
Old Dec 26, 2016 | 10:15 AM
minke's Avatar
minke
To Boaterguy and those who came after with the same sentiments,,, thanks. I read your post too quickly and didn't catch on. (FWIW I read "... cruising in the snow" instead of "... use cruise in the snow".) Point taken.
To follow thru: the wrench hasn't come back and I guess nothing is wrong. I'd still like to understand what the clunk was but I guess that won't happen.
Thanks. I appreciate your responses.
Fleetsuper
May 4, 2015 02:12 PM
ramsay
Jun 17, 2012 04:20 PM
dyoungen
Dec 1, 2010 04:34 PM
'94Mesquite
Aug 1, 2009 10:13 PM
scoug001
Oct 15, 2008 02:30 PM
