The truck is dying when I hit the clutch while coasting
The other day I let it idle for 15-20 minutes the other day and it at one point slowed down and almost died then picked up like nothing happened
21 engine coolant temperature sensor out of self test range
Bad temp sender?
45 Secondary Air Upstream During Self Test
46 Secondary Air Not Bypassed During Self Test
I've got the the idle thing propped open a bit to prevent dying is that why I got these codes
