Codes
Old Dec 18, 2016 | 05:25 PM
Rollingscrapmetal's Avatar
Rollingscrapmetal
Codes
The truck is dying when I hit the clutch while coasting
The other day I let it idle for 15-20 minutes the other day and it at one point slowed down and almost died then picked up like nothing happened
21 engine coolant temperature sensor out of self test range
Bad temp sender?
45 Secondary Air Upstream During Self Test
46 Secondary Air Not Bypassed During Self Test
I've got the the idle thing propped open a bit to prevent dying is that why I got these codes
77 Operator Error Dynamic Response Test
The dfo is busted
52 Power Steering Pressure Switch Circuit Open
The steering works fine
Old Dec 18, 2016 | 05:45 PM
My4Fordtrucks's Avatar
My4Fordtrucks
This is on your '74????
Old Dec 18, 2016 | 06:42 PM
Rollingscrapmetal
91 f150 302 5 speed
Old Dec 18, 2016 | 10:04 PM
joey2fords's Avatar
joey2fords
did you bring the engine up to full operating temperature before reading codes ?
Old Dec 18, 2016 | 10:08 PM
My4Fordtrucks
Do you have the p/s pressure switch and did you turn the steering wheel during the test?
What is a dfo?
Old Dec 19, 2016 | 01:04 AM
Rollingscrapmetal
I didn't turn the steering wheel during the test was I supposed to I've never gotten the code before
I let it run but maybe not long enough to get it up to temp again I've never let it get hot and still never had the code before
Dumb **** operator
Old Dec 20, 2016 | 08:55 PM
Rollingscrapmetal
It definitely has a bad temp sender
Bowman85merc
Dec 21, 2015 10:13 AM
Grems4ever
Nov 18, 2015 09:02 PM
Rico47635
Mar 5, 2011 10:59 AM
glasseater
Nov 13, 2008 09:53 PM
Hiflyer746
Oct 22, 2005 09:21 PM
