Sponsored by: Real Truck
why is it doing this?
Old Dec 18, 2016 | 05:43 AM
GREENHORN79's Avatar
GREENHORN79
I drive a 2010 with 80,000 mile on it. i don't drive it fast. I where i work the parking lot is off a main road and sometimes it a drag race to leave. when i leave it takes off ok but then it act like it doesn't want to shift or the turbo doesn't want to fully kick in. The truck act confused on what to do. if i let off the pedal then ease back in it it dose fine. I have let the truck warm up before going and still the same results. This is my first super duty and I'm the original owner of the truck. thanks for the help.
Old Dec 18, 2016 | 05:53 AM
seville009's Avatar
seville009
Just for the heck of it, turn off the stability control/advancetrac and see if that changes anything (have to turn it off each time you start the engine).
Old Dec 18, 2016 | 06:53 AM
GREENHORN79
My truck doesn't have stability control. but thanks I'm trying to figure it without buying a programmer
Old Dec 18, 2016 | 10:04 AM
Mike189677's Avatar
Mike189677
Have you had it checked for codes you can have codes even with no check engine light you need you diag the truck properly not throw a tuner on it putting a tuner on a truck that's not behaving it's self to begin with is just going to cause you more problems. You don't say wether it's always done this since new since your the orginal owner or it just started. There is also a 6.4 forum here in the diesel section and I'm sure some guys over there are very fimliar with the in and outs of the 6.4 and can help you diag it right.
Old Dec 18, 2016 | 11:38 AM
GREENHORN79
ok thanks for the help i will ask in that section.
Old Dec 18, 2016 | 01:03 PM
speakerfritz's Avatar
speakerfritz
hows the air filter
Old Dec 18, 2016 | 01:36 PM
GREENHORN79
that was my first thought. i changes it and it is still doing it.
erikkloss
Jun 7, 2013 12:14 PM
brandon1234
6.4L Power Stroke Diesel
Aug 17, 2012 08:08 PM
SUCKMEUP
20
Nov 29, 2007 08:57 AM
powerstroked162
Jul 11, 2007 03:50 PM
kc2006
Feb 18, 2005 11:27 PM
